Hello all,
Hoping I can get some help in the category of methanol injection! I am considering this for my current project car and was hoping for some help understanding the system and it's components, installation process and anything else you might want to add!
I'll be posting this in a few other locations
By the way, my project is a 2010 535i X-drive, 6mt.
Look at Aquamist, snow performance, and aem and you will find some systems and learn a lot. I use Aquamist but it's the most expensive. Have been using Aquamist for over 15 years.
Meth Injection is good for cooling intake
I'm a big fan of Snow Performance, I run their Stage 3 N54 set up on my daily, it was very easy and straight forward to install. Reliability with their kits is also fantastic. As pbonsalb said Aquamist is also great, I've used their stuff in the past never with a single issue.
-James
I'm installing an AEM kit right now but having issues with the MAP sensor reading. The stock MAP is reading 5v at idle and approaching zero when we open up the throttle to full - the reverse of what I need for the controller. Sure enough when we tested the pump it would spray full open at idle and reduce the amount of mist opening up the throttle.
Any and all suggestions would be of a great help. Bad stock MAP? Just use an aftermarket MAP?
I have been using the Snow Performance stage 2 MAF progressive kit for almost a year now, no issues. Took a little bit to get the MAF signal initiator dialed in, but it’s great for my application; to lower the IATs. My setup is post TB.
This info is probably not relevant to what you are doing, but just wanted to vouch for the reliability of Snow’s kits.
