I know that many people have done the solenoids on their zf tranny. I'm doing it right now, but have hit a pause while I awaity the arrival of the missing foam strip. What I am interested in, is, if anyone has used brake cleaner, or circuit cleaner to spray into the solenoid holes, followed by compressed air to "clear out" the little channels etc.?
I'm contemplating doing this, but I don't want to cause any damage and have to get the valve body rebuilt - too many tiny finicky parts inside that need to be moved out and replaced in the process.
gmak: The Good, the Bad, and the Ugly. A journey with my new-to-me 2000 540i
"Working on a BMW E39 is the best way to run out of time."
I don't have any experience with this but I probably would not do it. Just pull the old ones out and put the new ones in. If you are worried about dirt and debris in the valve body, it would probably be best to take it apart to clean it.
I had mine done and from my limited understanding of the valve body it's basically made out of aluminium in two parts. There is flat piece of separator gasket which you can buy and suppose to replace when you service the valve body. My mechanic used kerosene to clean the valve body so I don't see why you can't use contact cleaner or break cleaner to clean the part.
Incidentally I was using the same cleaners plus compressed air to clean the intake and exhaust vanos solenoids today and the car rough idle has gone.
Just to add that I had my valve body serviced and solenoid valves replaced a couple of years back but the last I took a fault code reader to check, it was throwing a fault code on solenoid no.3. So I guess I will have to replace that solenoid at some point. But car is still performing as usual.
BMW E60 530i & F30 320i
"Its sometimes better to shut up and be thought of as a fool than to speak and have all doubts removed"
