Results 1 to 16 of 16
Thread: Calibrating OBC temperature reading
    Virginia
    95 525, 93 M5, 05 X5 x2
    Can the OBC be calibrated to display an accurate temperature? Mine is off by about eight degrees. The sensor is new and is OE BMW.
    Dec 2005
    Melbourne, Australia
    E24, E34 x2, E36
    I guess. The sensor is only essentially a resistor that varies with temperature. Is it constantly 8deg too high or too low.
    If it's high the sensor may be Getting some outside heat influence. Make sure the sensor is in the direct air path and there is not a broken duct or something else creating more heat
    BMW’s
    90 E34 M5
    84 E24 M635csi standalone ecu with coil on plug
    94 E34 540i/6 SC 5-17psi Flex fuel/standalone ecu
    97 Z3 2.8
    97 E36 M3 euro SC still u/c
    OTHERS
    11 Audi S5 APR stg2
    19 Volkswagen Amarok V6
    Jan 2005
    Japan
    11/88 E32 750iL+98 E36M3
    Did you just install the new one? If so, just be patient, takes a long time to go to the correct temperature after it was disconnected.
    Virginia
    The sensor was installed correctly two years ago and there are no air leaks. It consistently reads high. This is the second, new sensor that behaves this way. Wonder if changing the OBC would make a difference. Also, wondering if the S38 engine generates so much heat that this problem is unavoidable.
    Jan 2005
    Japan
    OBC adjustments are only for Speedo correction http://bmwe32.masscom.net/johan/obc_...c_secrets.html
    Virginia
    OK, thanks.
    Dec 2005
    E24, E34 x2, E36
    Quote Originally Posted by GregT53 View Post
    u are probably correct with the s38. My m88/3 on board temp gauge reads high also. The e23 with the m30 is more accurate.
    Adding resostance may make it read higher. Unless u put the resistance on the incoming wire or even used a thicker gauge wire from the sensor to the obc. It's a lot of effort to get it reading right but I can understand the need to do so.
    BMW’s
    90 E34 M5
    97 Z3 2.8
    OTHERS
    11 Audi S5 APR stg2
    Virginia
    I may try using some heat shielding material around the sensor to block the engine heat. My E34 525 displays accurate temperatures so I am lead to believe it is the S38/M5, engine heat/bumper configuration that is the root cause of the problem. If I discover a remedy then I'll post it up for the good of the BF.C order.
    Virginia
    Update:
    I pulled the sensor from the bumper mount, letting it hang loose. Temperature reading is now spot on with weather service measurement.. Next step is to fabricate a heat shield to block engine heat from the mount area.
    May 2012
    Saskatoon, SK, Canada
    1994 525i touring
    When the car is started for the first time in a while (a day or more) is it 8 degrees high then? Or only once the car warms up? If it is 8 degrees high all the time I dont think it could be lack of engine bay heat control. My car reads high only after it is turned on after running and warmed up within the last few hours. After driving it will come down to accurate temp and stay there for the rest of the drive, even sitting in traffic. I have read (may or may not have been official bmw documentation or just heresay, I don't recall) that the obc will buffer a change in temp display if a significant temp change is sensed by the sensor when vehicle speed is low or stopped. This is to prevent heat from the engine bay to mess with the temp display in a slow moving vehicle.
    My first thought is there is corrosion/resistance in the wires and connections. (does more resistance = higher obc temp reading? I thought that was how thermocouples worked, but disconnecting the sensor makes the obc read a large negative number doesn't it?)
    Virginia
    Mine reads correct temperature on start up and then reads higher after driving for awhile, especially in warmer conditions. Last summer, when it hit 103, the temperature registered at 117 on the OBC.
    The fact that the reading is stable with the sensor unplugged from the bumper and dangling in open air leads me to conclude it is an engine heat problem. If the wires were corroded and increased resistance caused a higher than actual temperature to be displayed then it would have happened with the sensor unplugged.
    Jan 2017
    Amman, Jordan
    1995 BMW 525i Touring
    IMO. and from experience the temp. is not 100% accurate, it gives you an approximate reading of the surrounding air temperature, there are many factors to take into account, if you are driving in traffic, the heat from surrounding cars will effect it, also the heat from the surround air when the car is standing still, and some other factors.
    I notice that it is more accurate when driving at highway speed with little or no cars around. but in the city or traffic that's another matter entirely.
    E34 525i Touring 1995, M52B28 LSD... fully restored.
    May 2012
    1994 525i touring
    Yes, if it reads fine with a cold engine and then gets higher from there, it isn't a wire resistance issue I don't think. It even does it when doing freeway speed for a while?
    Jan 2017
    Amman, Jordan
    did you try to change the sensor?
    Virginia
    Sensor is new, BMW OE.
    I am convinced that the S38 produces sufficient heat to cause an inaccurate outside temperature reading.
    Evidence: 1) the temperature reading is accurate when letting the sensor hang in open air, unplugged from the bumper mount; and (2) my E34 525 using the same sensor does not have the problem.
    I used 3M aluminum tape and a heat shield fabric to create a cover that fits over the mounted sensor. Not elegant, but it works!
    Nov 2013
    Southeast
    They automatically adapt to the proper ambient temperature. It does take a while though.
  1. Replies: 2
    Last Post: 12-17-2013, 07:34 PM
  2. OBC temperature reads -22 F constantly
    By solomek in forum 1983 - 1991 (E30)
    Last Post: 10-15-2010, 10:15 PM
  3. OBC Temperature reading off
    By jmontoya in forum 1992 - 1999 M3 (E36)
    Last Post: 04-17-2008, 01:21 AM
  4. obc temperature reading...
    By tmyhilfgr in forum 1991 - 1999 (E36)
    Last Post: 03-07-2007, 06:58 PM
  5. Using the OBC temperature function for water temperature?
    By M3Jokster in forum 1992 - 1999 M3 (E36)
    Last Post: 05-15-2003, 03:16 PM
