Results 1 to 9 of 9
Thread: Anybody tried 450#F/600#R springs for track
    Aug 2009
    Metro DC
    79 323i, 94 325is, 13 M3
    I see many people trying 400/500 or 450/550.
    Ideally I would go much higher for track, but my struts are the Koni adjustable units TC Kline sells, and I don't think they're up to damping real track spring rates.
    450/600 is more of a spread than I see folks doing. But I will be running the Bimmerworld Ground Control front stabilizer bar, and a BMW 18mm bar on the rear.
    If I strike out here, I'll try the suspension forum.
    Sep 2008
    NS, Canada
    E36 M3
    Lots of people do a 150# or 200# split, I don't see an issue. This year I switched to 500F/650R and no rear bar to try a new autocross setup. Running the TCK SAs.
    If you have the TCK SA coilovers they should be good for up to 700 in the rear.
    Ottawa, ON, Canada
    e90 M3,X5,e46 racer
    Should be a good setup, if a little soft. Worst case, if it's really tail happy, you can disconnect the rear bar, though that might make it roll too much
    Check out the 8legs Racing page: https://www.facebook.com/8legsRacing/
    Apr 2014
    Castlegar,BC,Canada
    94e36M3RIP, 95 318 S50
    I have TCK 500/700 as an autocross setup. I like it over the 600 rear I had last year. Not as loose as I was expecting.
    You could always, try the setup and if you don't like how it feels, disconnect the rear bar and order lighter springs.
    Aug 2008
    St. Louis, MO.
    e36 332i
    I ran 400/500 and 550/650 on my tckline da's. No issues and managed to set a few track records.
    San Francisco, CA
    95 M3 GTS2/ST
    Quote Originally Posted by JBasham View Post
    Keep in mind that the motion ratio on the rear of an e36 about halves the spring rate as compared to the front. 600 spring is about 300 wheel rate. I run 600 front with 900 rear and a rear bar currently on a racecar with revalved Koni doubles. 100-150 spread is the typical 'safe' setup front to rear.
    Aug 2012
    Central, MD
    1995 M3
    Do you have the SA's or DA's? TCK will tell you the rear SA's are at their limit at around 600 (even though their web site says 750 I think). That said, I'm running 550/650 with their SA's, and damping is ok. I'm still have a touch of understeer in mid-corner, but have some front roll bar settings to play with. FYI, mine is E36.
    Aug 2009
    Metro DC
    WOW, thanks everybody, this is great info. I really appreciate it.
    I can't believe I forgot to say it's an e36.
    Yes, I have the Konis from TC Kline, 8241-1200 Sport. It's top-adjustable, rebound only. This is the rear shock I believe they push to folks buying their single-adjustable front coilovers?
    I was under the impression that 600# was about as much spring as I should put on that damper and expect it to survive longer term.
    I figured I'll try this and if it's just too soft, I will hit the Koni mobile service center for a revalve.
    Jul 2006
    Pittsford, NY
    various
    Telling us your vehicle's model and weight would be helpful.
    Keep in mind, the motion ratio between the Front and the Rear can be wacky on some BMWs.
    __________________________________________________
    Cars
  1. E46 WTB: TC Kline 600# Rear Springs for E46
    By niacin in forum BMW Parts Wanted
    Last Post: 09-20-2011, 04:36 PM
  2. E46 WTB: TC Kline 600# Rear Springs for E46
    Last Post: 08-29-2011, 05:25 PM
  3. Anybody have some coilovers or lowering springs for sale?
    By someguy2800 in forum 1983 - 1991 (E30)
    Last Post: 09-25-2006, 12:58 AM
  4. WTB 600/650lbs springs for M Coupe
    By Mcoupe67 in forum BMW Parts Wanted
    Last Post: 11-16-2004, 03:12 PM
  5. WTB 600/650lbs springs for M Coupe
    Last Post: 11-16-2004, 03:08 PM
