RM European Auto Parts
Results 1 to 7 of 7
Thread: loud grinding noise between engine and transmission E46
    Jun 2008
    LA
    2008 528i
    what could this be?
    https://youtu.be/Ch0MWebiaEo
    I'm guessing the small starter pinion is stuck engaged to the drive plate.
    but before I start taking the car apart I would like to hear other opinions.
    please help!
    MauiM3Mania's Avatar
    Jan 2002
    Central Pacific
    88M3 99M3 04M3 ITBx16
    That sounds ugly!
    88M3 AW 43k miles Project FS
    Jun 2002
    Aberdeen, NC (yes, again)
    E39M5, E500 4WD
    Dis you just install the transmission? The car didn't leave the factory with a red torque converter....
    Is the starter bolted up perfectly straight? If so, I'd guess that your flexplate is cracked.
    Chris Powell
    BMWCCA 274412
    Jun 2008
    LA
    2008 528i
    well the car ran fine with this setup for past 3 years... something just happened
    Jun 2002
    E39M5, E500 4WD
    That would then indicate the cracked flexplate.
    Chris Powell
    BMWCCA 274412
    NW suburban Chicago
    hiss by my window
    It sounds to me like the starter hasn't disengaged.
    Jun 2008
    LA
    2008 528i
    solved: starter was not disengaging properly. replaced starter.
  1. Replies: 9
    Last Post: 04-08-2017, 10:12 AM
  2. Replies: 10
    Last Post: 03-19-2014, 08:28 PM
  3. HELP! Grinding noise between 1st and second gear
    By qpooqpoo in forum 1988 - 1996 (E34)
    Last Post: 01-15-2010, 02:18 PM
  4. WTB: Plate between engine and transmission e36 6 cyl
    By bkelsey86 in forum BMW Parts Wanted
    Last Post: 09-17-2008, 12:49 PM
  5. grinding noise bt engine and auto tranny?
    By jayrnd in forum 1983 - 1991 (E30)
    Last Post: 12-22-2007, 11:09 PM
