Results 1 to 13 of 13
Thread: e36 motor and transmission mounts - what is the easy button these days?
    Kentucky
    14 m235i, 98 m3, 09 r56
    For a car that is not driven on the street except for to and from some events.
    I have seen UUC ones that didnt fair so well.
    AKG? Condor?
    Spanish Springs NV
    17 Sprinter, 94 325is
    I'm running akg 75d in mine. Only drive it on spirited drives and it's trailered to the track. Seem to be holding up just fine.
    Nov 2005
    MA
    Cayman S, Golf GSW, E30
    Bimmerworld solid rubber (group N) motor mounts and Rogue 95A tranny mounts is what i'm running. Same use case for me. I'm also running 95A diff bushings and 75D subframe bushings.
    I had 75D motor/tranny mounts in my old E30 track car, no thanks.
    ithaca Ny
    95m3/97m345/powerstroke
    Same here, bimmerworld and rogue with akg diff/subframe. Happy with the setup.
    Spanish Springs NV
    Forgot to add I'm also running aluminum subframe bushings and 75d everywhere else. Really not bad to drive on the street at all.
    oskaloosa,ia
    '01 3.0 ZCoupe
    I put in Condor mounts. Not sure how they will hold up as I just got them, but they seem to be working great so far. https://www.condorspeedshop.com/ I also got their front control arm mounts and solid rear subframe bushes. (Z3) and am loving them so far.
    Jan 2003
    Free America AZ
    German ones
    I'm using Vibra-Technics motor mounts with Rogue trans mounts. Fantastic combo especially if you're using a chassis mounted shifter.
    I wouldn't hesitate to drive this combo daily, but I do trailer to the track.
    Dave
    '18 RAM 2500 Laramie Cummins
    '15 Pure White VW Touareg TDI
    ///'95 Avus M3 S54B32 Race car -- 2022 ProAutoSports PS1 Champion
    ///'72 Chamonix 2002 (Restoration project)
    Dec 2005
    utopia
    17 F250 12 Merc C250
    Second for condorspeedshop.com I have their stuff on my E30 as well as my E36.
    Chris Leone
    chrisleonemotorsports.com
    roll cages, repairs and racecar fabrication
    1984 318i now 325is
    1994 325is STU racecar
    1988 325is donor
    Springfield, IL
    '95m3(Avus)/996tt/4.8is
    Quote Originally Posted by XXLBIMMER View Post
    Just put Condor in my subframe, will let everyone know how I like them after this weekend!
    washington dc
    Avus Cosmos Calypso!
    BW groupe N replica rubber motor mounts and Rogue rubber trans mounts. I would consider the e21 rubber trans mounts with aluminum cups and stock motor mounts too for a street car next time.
    Upstate NY
    '91 BMW 318is,'95 M3
    After sheering through a couple right-side UUC motor mounts in my E36 M3, I put in AKG 75D motor and tranny mounts but the car was not fun to drive even for short transits. I switched the tranny mounts to a set of Rogue ones I had previously bought from BW and it's a much better ride now.
    '91 E30 318is - Dinan chip, K&N cone intake, GC coilovers/camber plates, Koni shocks, ST sway bars, Supersprint exhaust.
    '95 E36 M3 - cosmos intake, 3.5" HFM, 24 lb. injectors, Vorshlag AST 5100 coilovers/camber plates, TMS sway bars, UUC exhaust.
    Cleveland
    135i, e36, A4 Avant
    Quote Originally Posted by MPWRCPE View Post
    Pretty much agreed. I'm using Vibra-Technics engine mounts and Bimmerworld trans mounts, after breaking a Vorshlag engine mount at Nelson Ledges. The Vorshlag engine mounts are junk IMO - why put a three inch long stud in bending and shear? Granted, Nelson is pretty much a durability test road, but still, come on.
    http://www.vibra-technics.com/bmw/e3...t_engine_mount
    I think a good alternative would probably be the Bimmerworld Group N replicas.
    IMO avoid urethane. I think engine / trans mounts are a bad application for this good material. Many don't have problems but I did.
    Chris
    Minneapolis
    1995 M3 Coupe
    Group N rubber in mine too. I tried the harder stuff and the vibrations were extreme, especially on the overrun, and distracting. Instead of concentrating on racing I kept on thinking the car was breaking.
  1. Replies: 3
    Last Post: 01-17-2014, 04:55 PM
  2. E36 E36 / E46 / Z3 Turner Motorsports Aluminum Motor and Transmission Mounts, Solid
    By m3mobbin in forum Drivetrain & Transmission Parts
    Last Post: 01-16-2014, 04:18 PM
  3. E46/E36/Z3 Solid Motor and Transmission Mount Kit
    By calundeen in forum Drivetrain & Transmission Parts
    Last Post: 10-01-2013, 11:03 AM
  4. AKG Motor and Transmission Mount Set for BMW E36 E46 Z3 Z4 M3
    By imagine02 in forum Engines, Performance Parts & Software
    Last Post: 08-16-2013, 05:29 PM
  5. FS: E36 motor and transmission mounts
    By moconnor in forum Engines, Performance Parts & Software
    Last Post: 04-06-2009, 03:18 PM
