Results 1 to 25 of 48
Thread: The E36 Turbo 5.3 dubbed Project "Punisher"
    NY
    325i, 530i, F250
    I am starting this post to document my Turbo 5.3 build that ive been working on for the past few years. The car started off completely stock with a few Dinan upgrades. It was a 2 owner (Father then Son) California car which was VERY well taken care of. Some of you may even remember when I was parting the car out a few years ago and how pristine condition the parts were. Anyway I wanted to build something that would breathe fire and scare people and quite honestly just not make sense to most people. My first task was completely stripping the car down to the essentials. Basically a rolling chassis minus all of the wiring. Its much easier to start over from scratch then to be tracking down wires. Originally I was just going to do a junkyard 5.3 with a turbo. That quickly faded as soon as I got the motor and started disassembling it to "clean" it. Well once everything was taken apart I started buying parts to put it back together to make it better then stock. And so it begins.....Folks dont ever start a project without a budget. It is VERY easy to get carried away. Anyway heres some pics ive taken thus far. Ill update the thread with photos as I progress at the point im at now (Almost running). Thanks and enjoy
    NY
    325i, 530i, F250
    Vorshlag style motor mounts
    Powder coated
    Engine tear down
    NY
    325i, 530i, F250
    NY
    325i, 530i, F250
    NY
    325i, 530i, F250
    NY
    325i, 530i, F250
    Huntsville Alabama
    99 LSX M3
    Nice paint work. Holy crap on all that wiring
    What parts are you changing in the L33 before the turbo?
    What is your clutch setup going to be? My LS7 Clutch is sticking and I am looking for new solutions.
    99 LSX M3
    NY
    325i, 530i, F250
    Thanks, I only changed a few things in the motor, it now sports an LS9 cam, LS1 intake, Pac 1218 valve springs, new rings hand filed to accommodate boost, Head studs, all new bearings, new oil pump ported and matched, hardened pushrods, and the whole motor was gone through and honed, valve job etc at the machine shop. As for clutch its a spec stage 4 good for 832 ft lbs torque and I forget the name of the flywheel but I remember it was REALLY expensive and I found it on ebay for a steal because the seller just wanted to get rid of it.
    NY
    325i, 530i, F250
    20170302_101838.jpg20170302_155700.jpg20170303_180841.jpg20170325_183720.jpg20170326_143929.jpg
    Custom Turbo Brace / Fender prep 4" fender dump Reinforced subframe
    NY
    325i, 530i, F250
    Finished the cold side piping today. Not bad for never having welded aluminum and only 30 minutes practice. Also finished the oil feed and return lines.
    Apr 2012
    Stuttgart, Germany
    1997 M3 / 5.3
    Great project. The fender exit exhaust will scare pedestrians!
    Will the turbo fit beneath the factory hood?
    Mar 2004
    USA
    96 328is 6.0L
    When you said that you want to make a fire breathing monster, you meant it litteraly with that fender dump exhaust . Cool project. Can't wait to see that thing breathing and roaring.
    Quote Originally Posted by Tim Mc View Post
    LOL Oh I'm sure it absolutely would! If you raise it about foot to foot and a half
    NY
    325i, 530i, F250
    Yeh im definatelt not fitting the turbo beneath the hood. Props to the guys who build there cars and fit everything into the e36 engine bay. Its very cramped in my opinion and I didnt want to do a scavenge pump...Few new updates and pics...I plumbed in a ps cooler in the pass side fog light hole. I have a brake duct from bimmerworld to go into the drivers side foglight hole so it will look a little more uniform. Im currently working on fitting the e30 coolant tank into my engine bay. Then after thats done I just have to do my dual pump setup with returns, a little wiring and get it started. Im trying to slay the streets this spring/summer. 20170424_201947.jpg20170425_103905.jpg20170425_103925.jpg
    NY
    325i, 530i, F250
    Also was able to get the Wastegate dump finished.....
    My buddy stopped by with his Silvia so we could to do some work on it.....After going for a ride in the Sylvia I am plenty motivated to get mine done!
    NY
    325i, 530i, F250
    Quote Originally Posted by helihansen View Post
    Did a bunch more work since the last post. Ended up purchasing the whole rear dropout from Dburts car....Fully reinforced and welded the rear subframe and subframe mounts on the underbody of the car, Rtabs etc...To date car is running and driving I just need to finalize some body work and complete the wiring...
    Sent from my SAMSUNG-SM-G930A using Tapatalk
    NY
    325i, 530i, F250
    Also installed a roll bar, seats and 6 point harnesses....Made seat mounts, and reinforcement plates for the belts..
    NY
    325i, 530i, F250
    Fuel system Aero 380 -8 feed, -6 return...
    Oct 2013
    Portland, OR
    328i,740i,e36 m3 x2,e46
    Just seeing this thread now, great work so far! You ended up going with a 210 diff correct? What trans are you going to be running?
    NY
    325i, 530i, F250
    Thanks its been a long road. Yes im using a 210 diff and a built T56 trans.
    NY
    325i, 530i, F250
    Heres some pics
    NY
    325i, 530i, F250
    Well the project is nearly done...Took the car out the other day and drove it about 5 miles...Only issue was the oil pressure being at 65psi was pushing the oil past the compressor housing so I took a set screw and drilled a 1/16 hole in it (.062) and then tapped my an4 turbo feed fitting
    NY
    325i, 530i, F250
    Turbo fitting modified
    NY
    325i, 530i, F250
    Passenger seat fire extinguisher mount
    NY
    325i, 530i, F250
    Fabbed up battery hold down, the old central lock switch in the center console is now a push button for the reverse lockout solenoid
    NY
    325i, 530i, F250
    Reverse lockout switch
  1. E36 FS/FT: 1995 M3, Alpine White 550whp TRM turbo... THE e36 M3!
    By naudlee in forum 3 series & Z Series
    Last Post: 12-06-2010, 03:36 PM
  2. Who in the USA was the first to offer a turbo kit for the e36 and when?
    By Turbo Charg Dynam in forum Forced Induction
    Last Post: 06-25-2005, 06:22 PM
  3. Saw the coolest Turbo E36 Widebody in San Diego today.
    By Sephiroth619 in forum California sponsored by Avus Autosport
    Last Post: 04-05-2005, 01:02 PM
  4. To The Guy in the Silver Turbo e36 2D Over By Cal Expo Sat. Night
    By DevusM in forum California sponsored by Avus Autosport
    Last Post: 02-08-2004, 10:47 AM
  5. Replies: 0
    Last Post: 07-17-2003, 11:47 PM
