After almost 2 years of waiting, I finally received the drivers side CSI mirror assembly (note to self, if you want something, don't wait as it may never be available when you finally decide to buy it (I got lucky this time!)). The parts are in the paint shop as I type. Is there a DIY on how to remove the old mirrors? Once installed the CSI transformation to the exterior will be complete
2016 Macan Turbo
2009 Porsche 911 Carerra S (997.2)
2013 BMW 135i Convertible
Remove door cards. Remove mirror "sails" (covers). Use a hex bit to remove the 3 screws securing mirror. Pull off old mirror.
Are you reusing your original motors or did you buy the ones with the appropriate motors already in them (I think they all come with motors, but can't recall)?
You will want to swap the sound deadening inside the mirror base over to the M tech mirrors. It is not available separately and the new mirrors don't come with them. Also note the white putty that covers the wiring to prevent moisture and wind noise. There should also be a plastic sheet that covers everything as well.
What "thumbs up" really means
Did yours have the following problem / issue?
https://www.bimmerforums.com/forum/s...-major-problem!
Mind to share where you found yours? Been looking for a pair for a long time and it's backordered everywhere..
I drilled some holes and installed e36 m3 mirrors . Look the same and will save a ton of money if you don't mind a little work .
I do not know, as I mentioned mine are at the paint shop currently. This wasn't something that ever would have crossed my mind to check. I am now freaking out a bit. I just left a message for the shop to check the drivers side mirror out to see if it is threaded. I will report back once I hear back.
Just out of pure luck I called BMW Toronto 3 weeks ago to see if any mirror assemblies had been re-released yet and to my surprise they had and there were a few left so I grabbed. I paid way too much for it mind you (but what are you going to do). I didn't want to do the E36 M3 conversion that TheShark850 and others have done.
Deleted. Apparently my advice and expertise isn't needed or wanted when it comes to E31's
BMWNThZST, Thank you for the follow up. No mine where procured through Gault BMW which received it from BMW, I had been waiting for it for a year with one side painted waiting for the other. Honestly, I didn't even check but another member noticed (thank god) before painting.
Maybe, I got unlucky and this was a one off..........
BMW 850 CSI march 1994 (EU spec), SOLD. https://www.classiccars-forsale.com/...94-bmw-850csi/
BMW 850 CSI november 1994 (EU spec)
M3 base is the same, just different holes. I bought some and placed them on the car. You would need to drill new holes, but the base fits. They have to be coupe only mirrors. Maybe there is a slight difference from CSI mirrors, but i do not think anyone is going to notice., and you can get a set for 100-200 dollars
Ive got some coupe mirrors and Engle bases but to date I've not bothered converting. How easy was it to drill holes in the M3 bases? As they are hollow-ish surely you had to add some weld or something to create new mounting points to drill into? Love to see how you did it as the thought of trying to make the shoddy Engl bases look good fills me with dread.
Finally got around to installing the new CSI mirrors yesterday.
And they look good.
Desecrator of all things Sacred
I have to say, I'm prob the only guy around who doesn't like CSi mirrors.
Personal taste and that they are too small.
Board Member of SoCalEights (Marketing, Web Development & Social Media), Vice President: BMWCCA/E31 Chapter, www.cartiologyfilms.com
Current E31s:
1997 BMW 840Ci Black on Beige. CSI 62, 107 and 16. Euro-CSi #892.
Client Represented E31s (Cartiology Films)
1994 BMW 850CSi #11 USA, 1994 BMW 850CSi #31 USA, 1994 BMW 850CSi #58 USA
93-850Ci - manual 6 speed. 97-850Ci - M73 Steptronic. 94-CSi 125, 95-CSi 162 Daytona Violet, CSi 198 White on Red
Past E31s:
1991 BMW 850i. Calypso Red on Beige Nappa and 1995 BMW 840Ci. Bright Red on Beige Nappa
1997 BMW 840Ci. Black On Black Nappa, but changed to Dakar Yellow on Black Nappa and 1994 BMW 850CSi #27. Red On light Silver.
1991 BMW 850i. Automatic. Red On Black and 1996 BMW 850Ci. Automatic. Midnight Blue on Gray.
1994 BMW 850CSi. Black On Blak #107, Black/Black 97-840. White/White CSi. Silver/Silver 97-840
Wow...first time I've heard anyone say they don't like CSi mirrors.
I think they're a timeless design and still one of the coolest looking, well-matched mirrors you'll see on any car.
Having said that, they do often look better when viewed in person, rather than in photo's.
As for practicality - sure, they're a compact size, but this is largely offset anyway, by the superb all-round visibility that the pillar-less E31 coupe design already offers.
Apologies to the OP, but I fear we may have just hijacked this thread with a whole new discussion topic......
Current:
1994 E31 850CSi Sterlingsilber/Anthracite Buffalo
Previous:
1987 E28 M5 Delphin
1986 E23 M745iA Arctic Blue
1986 E24 635CSi Polaris
1976 E3 3.0 Si Arctic Blue
Well. Nico57 said he doesn't like them either.
I personally like the original mirros much more. They fit the car "size wise" and overall go better with the car, not to mention visibility. The M mirrors look better with M3's to be honest. Let's not fotget that the Original large mirrors were part of the original E31 design; hence why I think they look better on the car. CSi came later and they probably just said let's save money and use the M3 mirrors on the CSi. LOL.
I'm a CSi owner and would NEVER change my US-Spec original mirrors. That's just me.
Current E31s:
Past E31s:
Cosmetic appearance is definitely a personal preference having said that KiwiCSi is correct, they look much better in person!
Off topic here but did you know that "timeless design" is what my license plate says (TMLSDSGN).
Not to worry about going off topic, it's all good.
Welcome!
On the main page in any sub-forum (in the case E31) below the Announcement (which is in blue) you will see +Post New Thread (also in blue bold), click on it to open a new topic. I hope that helps you.
The US E36 guys often complain about visibility and order Euro glass (same for E36/E34/E31). Supposedly the US mirrors are narrow angled or something*.
All my cars I ever had, 2 E36's, which I still have, since 2006, have M3 mirrors. I don't know any better. So I'm so used to them, and provide enough visibility to me.
* I see the Euro ones are called "wide angle". They also have a nice blue tint. And the passenger side doesn't have that "Objects in mirror..." nanny text.
That's fair enough Alec...to each his own. If I owned one I probably wouldn't modify it either, just to keep it original.
CSi mirror is not found on any other BMW, so no parts commonality there and certainly no cost saving.
The US-spec CSi was however an overall cost-saving exercise over the EC-spec car.
Current:
Previous:
1987 E28 M5 Delphin
