Results 1 to 4 of 4
Thread: Good idea or bad idea e39 transmission cooler as my engine oil cooler for my LS swap
    Feb 2008
    Upstate
    2 Boosted,1 more left to
    Lightbulb Good idea or bad idea e39 transmission cooler as my engine oil cooler for my LS swap
    I am looking into doing an oil cooler on my E39 Ls swap and my question to you guys is it a good idea or bad one to use the oem transmission cooler thats upfront as an oil cooler ? Or just get an aftermarket one and run up front by the grill?
    Thanks in advance
    E39 LSX SWAP PARTS FORSALE
    NW suburban Chicago
    hiss by my window
    well, it is made for higher temps and pressures and already nicely integrated so I don't see why not. No need for trans cooler then?
    Somewhere, USA
    2000 “560i”
    I would take a hard look at the fitting sizes and do some research regarding flow. Every aftermarket filter relocation kit I've installed was at least 1/2" I.D. on the hoses and fittings. Obviously a filter relocate kit is different than a fluid cooler but the premise is the same: Is it of sufficient size to flow the volume required? I would hate for you to end up with a oil starvation issue with the cam bearings because the cooler had insufficient flow.
    my 2 cents....
    S.F.
    Feb 2008
    Upstate
    Quote Originally Posted by StolenFox View Post
    my 2 cents....
    S.F.
    Yes thats the two things I was worrying about was the flow and oil starvation thats why I through it out here it anyone did this
  1. Good idea or bad idea? Tire related.....
    By tsouzee in forum 1996 - 2003 (E39)
    Last Post: 09-02-2008, 09:02 PM
  2. Auto Tranny Oil Cooler as a Engine Oil Cooler?
    By JLac in forum 1992 - 1999 M3 (E36)
    Last Post: 10-14-2005, 04:14 AM
  3. Good idea or bad idea?
    By Volf in forum Tire & Wheel Forum sponsored by The Tire Rack
    Last Post: 04-04-2005, 06:37 PM
  4. Good idea or bad idea?
    By Jeff M3 in forum 1992 - 1999 M3 (E36)
    Last Post: 03-04-2005, 12:19 AM
  5. Lifetime Alignment - Good Idea or Bad Idea
    By Stockman in forum General BMW and Automotive Discussion sponsored by Intercity Lines
    Last Post: 09-12-2002, 11:28 PM
