I am looking into doing an oil cooler on my E39 Ls swap and my question to you guys is it a good idea or bad one to use the oem transmission cooler thats upfront as an oil cooler ? Or just get an aftermarket one and run up front by the grill?
Thanks in advance
E39 LSX SWAP PARTS FORSALE
well, it is made for higher temps and pressures and already nicely integrated so I don't see why not. No need for trans cooler then?
I would take a hard look at the fitting sizes and do some research regarding flow. Every aftermarket filter relocation kit I've installed was at least 1/2" I.D. on the hoses and fittings. Obviously a filter relocate kit is different than a fluid cooler but the premise is the same: Is it of sufficient size to flow the volume required? I would hate for you to end up with a oil starvation issue with the cam bearings because the cooler had insufficient flow.
my 2 cents....
S.F.
