Bimmerforums Upgrade Garage The Tire Rack
Results 1 to 8 of 8
Thread: E36 Inner plastic fender 17'' wheel compatibility
    Apr 2017
    Czech republic
    BMW e36, Ford Fiesta
    Hello, I just wanted to ask someone who has any kind of knowledge about fitting 17 inch wheels on e36. My question is, is it possible to fit 17 wheels with 215 tire, without removing inner wheel well liners from a wheel well? Would it be a problem with 7.5 or even 8 inch rim width? Thanks!
    Oct 2003
    Seattle
    99 M3
    Depending on Aspect Ratio. Stock 1995 E36 M3 came with 235/40R17, where as the 1996+ M3 came with 225/45R17, both on 7.5 width wheels. I've heard that 245/40R17s on 8.5 width wheels fit. Generally, the problem becomes tire-to-strut clearance not tire-to-wheel well/liner.
    Aug 2013
    1999 BMW M3 Coupe
    I think he's talking about an E36 non-M. They came with much smaller wheels than the M3, and I don't know about the clearances on those models.
    Apr 2017
    Czech republic
    Yes, the car is 1992 e36 320i sedan.
    Oct 2003
    Seattle
    99 M3
    Quote Originally Posted by Eevo View Post
    An E36 is an E36, the exceptions are the "ti" and Z3. Fitment is the same for "M" and non-"M", Coupe and Sedan.
    Oct 2003
    Seattle
    99 M3
    Quote Originally Posted by bluptgm3 View Post
    Unless you deviate from 'stock' backspace (ET41). generally ET35 - ET41 fits.
    Aug 2013
    1999 BMW M3 Coupe
    Ah, didn't know that.
    Then yeah, the stock M3 wheels are ET41 17x7.5 (225/45-17) and 17x8.5 (245/40-17). Those fit obviously. You can also fit 17x8.5 ET41+ with 245/40-17 all around without mods. Any wider than that and you'll need some amount of spacer up front to clear the strut, and if you go wider than 17x9 ET41+ 245/40-17 in back you'll need to start rolling fenders. You'll also want/need to have the ability to adjust your ride height and front camber if you want to push the boundaries of tire fitment.
    I'm running 17x9 ET42 with wide 200TW 245/40-17's all around with 12mm spacers in front and no fender work.
    Apr 2017
    Czech republic
    Thanks alot! I'll give it a try!
  1. E36 E36/7 Z3 Roadster 17" Wheels
    By ajy4490 in forum Wheels and Tires
    Last Post: 07-23-2010, 03:32 PM
  2. FS: e36 M3 LTW Motorsport 17" Wheels w/Spare
    By Brad @ evosport in forum Wheels and Tires
    Last Post: 06-10-2006, 09:58 PM
  3. FS: e36 M3 LTW Motorsport 17" Wheels w/Spare
    By Brad @ evosport in forum Race Cars & Track Parts
    Last Post: 06-08-2006, 06:39 PM
  4. E36, E46, M3, non-M3 wheel compatibility
    By brown9999 in forum Tire & Wheel Forum sponsored by The Tire Rack
    Last Post: 12-31-2004, 10:10 PM
  5. pic request e36 M3 with aftermarket 17'' wheels
    By yotone in forum BMW Rides & Events
    Last Post: 04-01-2004, 03:10 AM
