Originally Posted by
gdking32
I have isolated a common M54 oil leak at the oil filter housing. I have replace the oil filter gasket and (11421719855) and the 4 metal gasket rings (32411093596) but still have an oil leak. There is visible oil on the engine under the intake manifold. Checked our several repair videos on YouTube to confirm that I am doing what is required. Should I be using some type of gasket sealer as part of the process. Neither the Bentley manual or the YouTube videos mention use of anything other than a new oil filter gasket. Any advice is appreciated since I am hoping that three times is a charm.
If the oil filter housing gasket was installed correctly along with new compression rings on the oil supply hose, I would suspect a crack in the oil supply hose. They get brittle with age making them prone to leaking if handled.
Current Garage:
91 e34 M5 - spoiled & demanding 27 y/o -glanzshwarz
91 850i/6 -another spoiled & demanding 27 y/o- schwarz-gone but never forgotten
06 325i - undeserving, spoiled & demanding 27 y/o daughter's DD-hellrot
03 MINI Cooper S JCW -spoiled & demanding, yet deserving wife's DD - Chili/Panther
05 X3 3.0i -family workhorse - diamond schwarz
12 X5 3.5d - torque monster - space gray metallic
86 GMC Cabellero - Old Faithful 32 y/o DD BMW Support Vehicle
08 Cub Cadet 19HP 46" hydrostatic- yard vehicle
88 Schwinn Sierra - 1WD Off Road Vehicle
e31 & OHC BMW CCA #385540
