Results 1 to 3 of 3
Thread: tire rubbing question
    1995 BMW M3
    Hello all, I just purchased a 2001 m3 and it had a very stiff suspension on it. So I swapped it out with some koni yellow adjustables with some H&r sport springs. The ride height is great, however, I am getting a rub on my back wheel over bumps. I have a few questions if anyone can help.
    Will an alignment help with this?
    Will stiffening the shock help with this?
    I know my option is to roll the fender, but just wondering about the first two questions before I do this?
    My tire size in the rear is 275/35/19
    Seems there was no rubbing before, but then again, it was a different shock set up.
    Pelican Parts's Avatar
    Pelican Parts is online now Senior Member Supporting Vendor
    Aug 2013
    Harbor City, CA
    '02 E39 Touring
    Check out the link below for wheel fitment and spacing. It's a great, easy to understand guide. A stiffer shock, like the Bilstein B6s, would help; but it likely has more to do with the wheel/tire combo.
    888.280.7799 | 6am - 5pm PST
    Jul 2006
    Pittsford, NY
    Your diameter is 26.58" - which is more than a half inch bigger than stock, so you're killing your gearing AND creating the rub. You might try adding in a bit more rear camber but the tire size is the killer.
  1. tire rubbing question
    By crc13 in forum 1999 - 2006 (E46)
    Last Post: 04-17-2017, 04:03 AM
  2. Quick tire rub question
    By phast in forum 1991 - 1999 (E36)
    Last Post: 01-30-2009, 11:11 AM
  3. Tire Rub / Camber question
    By Kevin E21 in forum 1975 - 1983 (E21)
    Last Post: 03-24-2007, 06:13 AM
  4. Rear tire rubbing question
    By code7rpd in forum 1996 - 2003 (E39)
    Last Post: 06-23-2006, 03:32 PM
  5. Tire rub + caster questions
    By vlksdragon in forum 1991 - 1999 (E36)
    Last Post: 02-01-2006, 07:33 PM
