Results 1 to 2 of 2
Thread: tire rubbing question
    Wisconsin
    1995 BMW M3
    Hello all, I just purchased a 2001 m3 and it had a very stiff suspension on it. So I swapped it out with some koni yellow adjustables with some H&r sport springs. The ride height is great, however, I am getting a rub on my back wheel over bumps. I have a few questions if anyone can help.
    Will an alignment help with this?
    Will stiffening the shock help with this?
    I know my option is to roll the fender, but just wondering about the first two questions before I do this?
    My tire size in the rear is 275/35/19
    Seems there was no rubbing before, but then again, it was a different shock set up.
    dworthy's Avatar
    Nov 2010
    Grafenwoehr, Germany
    16 220i 05 325it 05 M3
    Rolling the fenders would be my first choice, as that way if your rear suspension goes to max, you don't have to worry about it rubbing.
    An alignment won't do much beside change the toe in/out in the rear, so if you have an odd wear pattern on the tires, then you would need aligning.
    As for the shock, it's job is to keep the spring from bouncing you all over the road. Your ride height is determined by the spring.
    You could change the camber, however that would require replacing the lower wishbone support with an adjustable one from say ECS Tuning.
    Darin
    Current:
    Past:
    79 525 euro Green/Green RIP
    M-Flight Member
  1. Quick tire rub question
    By phast in forum 1991 - 1999 (E36)
    Last Post: 01-30-2009, 10:11 AM
  2. tire size fit/rub question
    By deutscheEnergi in forum 1975 - 1983 (E21)
    Last Post: 04-10-2007, 03:04 PM
  3. Tire Rub / Camber question
    By Kevin E21 in forum 1975 - 1983 (E21)
    Last Post: 03-24-2007, 06:13 AM
  4. Rear tire rubbing question
    By code7rpd in forum 1996 - 2003 (E39)
    Last Post: 06-23-2006, 03:32 PM
  5. Tire rub + caster questions
    By vlksdragon in forum 1991 - 1999 (E36)
    Last Post: 02-01-2006, 06:33 PM
