Brembo GT-R BBK kit for BMW E46 M3 (2001-2006) and Z4m Coupe/Roadster (2006-2008)
Sale Kit price $4700 Ships from Atlanta GA.
New from Turner Front $4350, rear $3414 but Turner kit does not include pads, and you cannot get the Type 2 Jshape discs from them.
20170415_205642308_iOS.jpg20170415_205419995_iOS.jpg20170415_205343888_iOS.jpg20170415_205323410_iOS.jpg20170415_205658950_sm.jpg
What you will receive with the sale
Front Setup
Brembo GT 6-piston 380mm Monobloc Calipers 380x32mm
model 9001A series Stamped S/N 20.9733.02/.01 Kit S/N 3K2.9022A
2 Piece disc (hat & Type 3 rotor) Discs have 32mm remaining so essentially new.
Brembo Engineered CNC Billet Caliper Adapters
Front Pads Hawk DCT-70 pads – almost new with 10mm remaining
Instruction packet and included details from Brembo
Fitment Note: Use the fitment guide below for your front sizing. You will need a rim that has clearance of 17 1/8” or ideally greater in the center where the caliper will be aligned. Spacers can help with this as wheels inside diameter are tapered. The kit fit with Advan TCiii 18x9.5 et22 rims without spacers, and Should fit Apex based on mounting test. Use guide below to measure if you want to know for sure.
Guide ->http://www.racetechnologies.com/arti...rake-clearance
380mm Front http://www.racetechnologies.com/site.../1M1.9001A.pdf
Rear Setup
Brembo GT 4 piston Monobloc Calipers 345x28mm
Model 8001A series Stamped S/N 2 20A09202/01 Kit S/N 4K2.8009A
2 piece disc (hat & Type 3 rotor) Discs have 27.35mm remaining
Hawk DCT-70 pads – 10.55mm remaining
The kit has Brembo original Discs included in sale. However, I was going to begin using non-Brembo to help with the race budget. To save your research, I’m sharing mine.
Best place I found for pads
G-Loc - http://www.g-locbrakes.com/products/...e-kits/search/
· Front: GPBBK $268 R12
· Rear GP592 $196 R10
Rear https://www.zeckhausen.com/catalog/i...hp?cPath=82_84
Front https://www.zeckhausen.com/catalog/i...p?cPath=82_912
Best place I found for replacement discs
Rear http://www.girodisc.com/Rotors_c_1213.html
Www.ColemanRacing.com. Front rotors $275 Rear Rotors $250
Front https://www.zeckhausen.com/catalog/i...h=82_1516_1518 $360
Rear https://www.zeckhausen.com/catalog/i...h=82_1516_1517 $335
