So I hooked up the lights again this evening and man are they bright. Will post pics later.
Tomorrow I'll try and finish up sorting out the AE stuff and hopefully put everything back together.
This is with the headlight just sitting on top of the bumper and not actually bolted in.
I then lifted it up slightly to simulate what it would be like at proper aim.
That looks fantastic. My morimoto bulbs are coming in today. Excited to put those in instead of the cheap pos bulb that causes a hot spot that's in there now.
Chris
04 Mercedes S55 AMG
97 BMW 540i6
That does look nice! Hard to tell 100% with all the background, but looks good from what I can see. Now slow down so I can catch up! I'm waiting on connector parts from BMW and TRS.
Dude, that light output looks awesome! I gotta get off my lazy butt and get back on my lights! So far, I have one of the housing opened up, but that's it.
Light output does look pretty good. Kinda hard to see clearly with the background, but looks to have a pretty sharp cutoff and good color band...
Alvin Caragay
Mpire Automotive (https://www.facebook.com/MpireAutomotive/)
'96 AC Schnitzer S3 Sport CLS Replica (https://www.facebook.com/ACSS3SportCLSR)
'02 E39 540iAT
Alright, so I need a little help here. I'm trying to figur out in where to tap in the interior light.
My harness kit is built like this:
- Four plugs that connect to the four SMD rings
- Two battery source wires; red wire with a 20A fuse in line (will hook it to + feed wire in the DME box) and a black wire (either grounded next to the DME box or behind the passenger side headlight ground source)
- One red wire that will tap to a DME power source
- One white wire that will tap to an interior light source
- One normally closed relay
So while I may have figured out where all other wires go to, I'm having a slight trouble with hooking up the white wire. Where's the best source to tap this one to?
I tested the SMD AE ring today and they looked super bright. Not really bluish in colour but really super bright. They look having a 6000K or 6500K scale. I'll post one pic later.
Pull one of the door panel lights and look at the wires going to the plug. One should be brown and the other red with I think violet stripe. All of the interior lights have the same color wire, aka puddle lights. Look back at my AE DEL thread and I say specifically what color it is. Look for that same color wire coming put of the lcm and tap into it.
-Paul
2003 "M5" - Full M5 conversion, AMG C63S 6 piston front calipers, Porsche Panamera 4 piston rear calipers, GC Coilovers, Eibach ARBs, UUC Evo3/DSSR, Borla Exhaust w/Muffler Delete, BMW NBT with Carplay/Android Auto, Bi-Xenons, e38 Style 37 M-Pars, e60 Hubs 530i 6-speed swap build thread2005 Range Rover 4.6is (M62TU Powered) - 4.6is Engine Swap from X5, BMW NBT with Carplay/Android Auto
Yep, I did pull one of the door light panels and it is a red and looked like a light blue-ish or like you said pale violet color. I was then trying to trace that wire back to the LCM but I couldn't find it for some reason although I think I saw a red/blue color but the blue was darker than at the door light. I'll pull out the LCM and look for it again.
-Paul
Reading right now. There is a red/blue on the GM.
Yes. Interior lights are from GM. See Pauls thread.
You know, I think I meant to say GM. My bad. Either way, the correct module was listed in my other thread post.
-Paul
Yep, I've seen the red/blue wire at GM pin 20. I thought I had to tap at the LCM side and was frantically looking for that wire, so that's where I was confused a little. Later did I realized the GM controls the interior lights. Quick question though. Any chance that wire also run up to the DME box?
-Paul
I don't think there is one.
Anyways, guess I'll have to pull this wire through the firewall and then tap it.
-Paul
I know you got me ...
Asim- why you running any wires to the ebox? All the DRL and Puddle light connection can be made near the glove box area right near the LCM/GM zone.
I've been wanting to retrofit PDC but am hesitating because I can already foresee the hours of hunching over the hood trying to run wires through the firewall while simultaneously asking myself why I put myself in these positions. Let us know how it goes.
Chris
04 Mercedes S55 AMG
97 BMW 540i6
-Paul
^echo
