Results 1 to 8 of 8
Thread: Problem with DIS and 635CSI
    Sep 2010
    Estonia
    2000 BMW 740i
    Hello. I have a JAP 635CSI, excellent condition. And I also have DIS with ADS support that works great. But, the diagnostic connector is the old type (15 pin) and I have a original adapter (15 pin to 20 pin). Sadly, it doesn't recognize the car. Do I need a older DIS or something else? Modic?
    Feb 2010
    Pontevedra, Spain
    318i M40 4-door
    As far as I know, the E24 has the old style diagnostic plug. BMW DIS and MoDiC are for cars designed after 1988 (facelift E30, E34, E32...). For the old cars, there was a huge diagnostic machine called the BMW Service Test (SUN 2013 Motortester). It was a huge computer with programs loaded through diskettes that was standard equipment for dealers at the end of the 70's. It was the only machine that can read that cars, and was used well up to the end of the 90's with several updates, although BMW DIS started to substitute it at the beginning of the 90s but with no support for pre-88 cars.
    Pretty cool geek stuff for BMW owners
    May 2013
    Moultrie, Ga. USA
    87 635CSi, 88 635CSi,
    So what do the guys that "rebuild" the early computers use to test or analyze them? Or do they just scope sections and check voltages, components etc...
    I wonder where those big dinosaur machines ended up? Very cool computer btw.
    warwick RI
    E30/E32/F25
    Have a sun machine at my shop . We use it to collect dust in the shop. Works very well
    Me E30 87/ 325i + F25 12/ M-Sport + E32 94/ 740i
    G/F’s E34 92/ 525iT + F48 18/ X1
    Feb 2010
    Pontevedra, Spain
    318i M40 4-door
    Quote Originally Posted by slofut View Post
    They could read error memory on some pre-88 models. The screen in the left is a microfiche reader, where the mechanic could read the workshop manual and the nominal values for measures. The middle screen is the computer screen, it shows the BMW Diagnose program. It could read errors from memory, actuate some components individually with engine off, and measure values as a voltmeter with several adapters for the ECU and other units. In older moderls you could attach to it vacuum tubes, voltage probes etc and do the readings for engine parameters measuring in the traditional way. The right screen is the oscilloscope for testing ignition and so on. It has even a printer to print error codes and ECU info to make warranty exchanges. Also, the very first MoDiC was loaded through this monster, with the aid of a serial RS232 cable.
    Sep 2010
    Estonia
    2000 BMW 740i
    I would love to have one.
    Jun 2015
    Fajardo uerto Rico
    1987 M6
    Jul 2018
    Netherlands
    1982 628CSi
    Very impressive diagnostic hardware indeed, very different to today. Imagine dragging one of those along instead of your laptop and an OBD-cable.
  1. [SOLVED] Problem with DIS v44 and short test
    By Volum in forum Diagnostic Software
    Last Post: 03-17-2016, 08:34 AM
  2. Problems with INPA and DIS with ADS
    By batmanqq in forum Diagnostic Software
    Last Post: 12-30-2011, 07:30 AM
  3. Any long term problems with SMG and track use?
    By 1BADM3 in forum 2001 - 2006 M3 (E46)
    Last Post: 12-22-2006, 04:07 PM
  4. Anyone experience problems with ABS and DSC after an event ?
    By JLee in forum Track, Auto-X & Drag Racing sponsored by Bimmerparts.com
    Last Post: 03-10-2004, 12:06 PM
  5. Problem with heat and A/C, need help...
    By Tommy in forum 1992 - 1999 M3 (E36)
    Last Post: 05-26-2001, 09:11 AM
