Results 1 to 5 of 5
Thread: 05 X3 overheads intermittently (weird oil light blinking)
    Jan 2005
    Motown
    2005 x3 3.0
    Howdy,
    90% of the time my temp is pegged at halfway like it's supposed to be.
    occasionally it will climb all the way to the red and beep. if I turn the car off and wait it will come down slightly.
    if I drive the car it will usually drop right back to 50% after a few seconds of driving.
    I bled the Radiator two weeks a gin and the issue went away temporarily. Now it's back.
    sounds like I have a slow leak letting air into the system. does that sound right?
    the only reason I wonder if it's electronic is that when the overheat light comes on every third or fourth time the oil light will come on, and it will kind of blink spastically then go off when the temp return to normal.
    my oil is a bit low, but why would the oil light come on then go off again?
    thoughts?
    Pelican Parts's Avatar
    Aug 2013
    Harbor City, CA
    '02 E39 Touring
    I would have the codes read to see if anything comes up. It sounds like a slow leak is possible, but it could also involve the radiator temp sensor. Check out the link below to our Cooling System DIYs, I hope you'll find some good info to troubleshoot with. Best of luck!
    http://www.pelicanparts.com/techarti...X3.htm#cooling
    -Dmitry
    888.280.7799 | 6am - 5pm PST
    Jan 2016
    Ca
    2001 525it
    Sound like it needs a coolant system inspection
    Jan 2005
    Motown
    2005 x3 3.0
    Thanks for the reply's guys.
    the system is not losing very much coolant and I have a new symptom.
    during the last two overheats (still 5-10 seconds long before dropping back to normal) the needle went out of the range to the right and the Red light turned off.
    has anyone ever seen that before?
    makes me wonder if it is the coolant temp sensor as the needle moves very quickly back to normal (like faster than an engine could cool) and now seems to be sending readings to the gauge that are out of the range.
    thoughts?
    Jan 2005
    Motown
    2005 x3 3.0
    Update,
    Water pump was bad, plastic impeller etc. etc.
    Got the parts from pelican for less than $100, for pump, pully and belt.
    Never used pelican before, very pleased.
    Car is happy now...
  1. Red Oil Light Blinking (Oil Pressure OK)
    By 325cibimer in forum 1999 - 2006 (E46)
    Last Post: 06-28-2016, 11:23 PM
  2. range rover 3.0 red oil light blinking
    By bebiloku in forum 2003+ X3, X4 (E83, F25, F26, F97, F98, G02)
    Last Post: 05-23-2014, 03:22 PM
  3. engine oil light blinks
    By jumbie23 in forum 1999 - 2006 (E46)
    Last Post: 03-29-2011, 12:54 PM
  4. Red oil light blinks on and off
    By michaelp in forum General BMW and Automotive Discussion sponsored by Intercity Lines
    Last Post: 06-23-2010, 08:25 PM
  5. Weird Oil Light problem
    By promking in forum 1983 - 1991 (E30)
    Last Post: 02-27-2009, 12:03 PM
