Results 1 to 11 of 11
Thread: Cost to upgrade to NAV?
    South Carolina
    2004 330 vert 2004 X5
    Looking at a 2004 330 vert. It doesn't have the NAV screen. How much do those units go for? Are they just plug and play?
    Mar 2015
    west chicago il
    01 E46 330i 5sp man spor
    Nav cars have the radio in the trunk near the amplifier. The wiring is completely different. Not worth the huge amount of rewiring that would be required for an outdated nav system. Buy a dynavin. It's plug and play and way more modern than the 20 year old technology of the oem nav.
    Sent from my SAMSUNG-SM-G870A using Tapatalk
    South Carolina
    Thanks.
    Jan 2016
    Ca
    2001 525it
    Use your phone
    Fresno,ca
    E46 E92 E70
    We are here if need us
    Jul 2011
    Arlington, VA
    2018 BMW M240i
    ^^^this!^^^
    Aug 2015
    Cologne, MN
    03 M3 00 740i 98 528i
    I HATE the nav in my 740i. Always glitching out and killing the battery. Im gutting mine out. I agree with others, dynavin or just use your phone.
    2000 740i - 149K - Dville Monsoon rear deck speaker upgrade, GROM audio Bluetooth
    1998 528i - 204K - GROM audio Bluetooth setup, Drilled/Slotted Rotors, BSW Stage One speaker kit, Facelift Xenon's with Angel Eyes
    2003 M3 - 210K - BMW Euro Cross Drilled Rotors
    Mar 2017
    Norwich, Connecticut.
    E46 wag. E36 convertible
    I recently installed a Garmin...03, xi, I put it dead center on the dash at the lowest point sucked to the windshield. The power wire was easy to hide all the way to the cigarette lighter.
    Osnabrock, ND
    2004 325xi,2004 545i SMG
    I have a car with factory NAV. I was wanting to upgrade it to the dynavan head unit. Ok so here is my question. When Installing this how does one get the anteanna lead up to the headunit. On the nav cars the anteanna plugs into the head unit in the trunk. What else has to be changed to install this on a factory NAV car.
    Level 1 Certified BMW tech.
    Mar 2015
    west chicago il
    Quote Originally Posted by 90turbo1 View Post
    There is a harness that you have to run from the dash to the trunk.
    Sep 2012
    El Paso Del Norte, TX, US
    ‘15 F31d Msport
    Factory Nav is not difficult to retrofit. You need the bordmonitor, the mk4 DVD Nav drive/computer, the bm53 or bm54 radio module, the Retrofit harness, amd a gps antenna.
    I have Nav/TV and there is no way on gods green earth I'd ever settle for dynavin or similar.
    If I were to give my Touring a first name, I'd probably name it "Alan".
    Mostly because I like puns.
    Mutual Admiration Society #5
  1. Looking to upgrade to 16:9 widescreen nav ?
    By miylive in forum 1995 - 2001 (E38)
    Last Post: 01-27-2014, 01:22 AM
  2. How to upgrade CD NAV to DVD navigation??
    By skiboard06 in forum 2001 - 2006 M3 (E46)
    Last Post: 10-30-2008, 10:16 AM
  3. How to upgrade MK3 Nav to software version 5.0
    By rg0115 in forum 1995 - 2001 (E38)
    Last Post: 06-26-2007, 02:18 AM
  4. Are 98 750s equiped with Nav2? And Cost to upgrade to Nav4
    By Auraraptor in forum 1995 - 2001 (E38)
    Last Post: 01-14-2004, 11:38 AM
  5. Need Advice on Whether to Upgrade to OEM Staggared M Rims
    By scottsby in forum 1991 - 1999 (E36)
    Last Post: 11-19-2001, 10:52 AM
