Is anyone using this antenna from ECS corporation? I'm curious about mounting locations. I'm thinking of mounting in the trunk, since that's were radio is located in my car.
Hi,
I guess you mean this; http://www.tunetrapper.com/index.html
Interesting to see if anyone is using it and can provide feedback, if not, be the tester and let us know how it works for you !
Cheers, Dennis!
I have ordered one, so I will check in with the results.
Ok, this product didn't work at all. The FM reception was actually worse and nothing improved for the AM. The eventual solution to my poor radio reception ended up being an application of Deoxit on the antenna connections at the rear window and cable into radio.
