Hi All,
I have a 2001 325i sedan, I haven't drive the car in a while because after changing the cooling system I notice that the coolant was leaking from the expansion tank cap. I change the cap and same problem. something that I notice is that car had a lot of pressure when was parked overnight.
Please let me know if you had this problem and how to fix it or what could be the cause.
Fernando
It could b 1 of 3 thing either a new water pump the thermostat or it is not bled tidy when you bleed the system as your looking at the car from the front jack the right hand side right up as far as u can so u get the bottle higher than the engine cause it sound like its not bled tidy
Sent from my SM-G920F using Tapatalk
Mine didn't leak but the problem sounds similar when I changed my coolant my car would run hotter and tons of pressure in the system... the problem was there was air bubbles in the system and it took a week for all the air to work its way out and me adding tons of coolant on the system
Maybe you have the coolant over filled. The top of the level indicator stick should just be poking out the neck of the ET. No higher.
If cooling system was replaced due to overheating, then damage may have been done to the headgasket.
Perform a cylinder leakdown test, while observing coolant for telltale air bubbles.
I've had the exact same to me, turned out to be a thermostat.
Thanks for being here.....You have a greatly better mechanical observation and help offering...than many here.
over pressure cooling system is almost always headgasket.
Current:
- 09 335i MSport, FBO.
- 98 Euro M3, Estoril Blue
- 04 M3, Carbon Black, 6 Speed Coupe
- 06 M5, Black on Black, Full Leather.
- 73 3.0CS, Tagia Green, 5 speed M30b35 converted
Ex's: 1984 325e, 1988 325IX, 1992 525I, 1995 540i/6, 2002 330i, 2005 330xi, 1992 850i, 2003 330i #1, 2003 330i #2, 2002 330ci, 2004 330ci, 2007 328CI, 2007 335i, 2001 M3, 2006 M5 6 speed
Interrupt once the cooling system....Check back all procedures as if all cooling system parts were replaced.....Just as if as a pilot take off procedure...upon the next flight! Remember..the BMW cooling system needs to be 'burpped'...a 'burp' screw...is attop ..a mechanic will know.
