Results 1 to 25 of 43
Thread: Value?: 1997 220K Auto 4 Door M3
    Apr 2012
    Stuttgart, Germany
    1997 M3 / 5.3
    Appreciate a few comments on the value of a 1997 4 door automatic M3 with 220,000 miles on the odometer (All STOCK).
    Nearly original paint (8 small dents/no rust), good wheels, interior is only a 7 of 10, likely FL car its life, with three lights on the dash illuminated: Air Bag, Check Engine, Check Control.
    I can tell the struts are worn, low brake pedal, some missing items such as the radiator undertray, one damaged front inner wheel wheel liner, etc.
    Price is $4500 OBO...I'm leery of the trouble lights...I'm not BMW smart...
    Thanks.
    Dec 2016
    vero beach, FL
    1997 328ic
    You should be leery. That sounds like a car that hasn't been maintained is on its last legs and is typically on classifieds for $2k for enthusiasts looking for parts car. You can likely find pristine M3 for 8k-10k and avg 150k car for 5k.I say so because I was in the market for several months myself and went with pristine 75k 97 2.8 for 5K. If you must have that car at least find out what's behind the lights and maybe have local garage do inspection and compression test. And start your bidding much lower.
    M_3_X's Avatar
    M_3_X is offline Breaking Stereotypes BMW CCA Member
    N. Miss - Memphis TN Area
    '02 M3, '05 X3, '91 E30
    As said above, you should be ver leery and take it for a PPI.
    Pictures will help to make a determination but based on your description, mileage, the fact that is not a coupe, and it's an automatic; if it runs and shifts good, I would say that's a $2,500-$2,800 car.
    Good luck.
    "If everything seems under control, you're just not going fast enough"
    -Mario Andretti.
    _____________________
    River City Bimmers Chapter
    2002///M3 Coupe, Steel Gray Metallic on black leather, three pedals.
    2005 X3 3.0i ZPP, Black Sapphire on Terracotta.
    1991 E30 325ic, AW, Black leather, Black top, three pedals.
    Jan 2016
    Ca
    2001 525it
    To much money to many miles, keep looking
    Jun 2016
    Palatine, IL
    2005 BMW 330i ZHP Sedan
    I would not pay more than $2500 based on the information you provided. Personally, I would seek out a lower mileage, manual transmission vehicle without numerous dash lights illuminated. Cars that are not well maintained tend to be money pits. And do you want to sink $ into an automatic sedan with 220k miles?!? You would not recoup your investment when you sell later. Just my $.02
    Sent from my iPad using Tapatalk
    Jul 2010
    Murrieta, CA
    '94 325iC, '08 328i, E93
    Check Control is your problem to cure if you buy the car. It can be something as simple as a burnt out tail lamp or headlamp. The Check Control Module tells you that the coolant is low, lamps are out, basic operator maintenance items that people with more mundane cars have to walk around the car and inspect for themselves.
    AirBag light is an issue that may or may not be important to you. People drove around for 100 years without airbags, this light means you are among that substantial population. It can be due to a maintenance activity that resulted in a seat being removed from the car, then the ignition was cycled ON with the seat gone. The car goes out and polls all of the components of the SRS (Supplemental Restraint System) to see if they are there, if any component fails to check in, then the light is set. Even if the fault goes away -- the seat is reinstalled -- the light remains on until it is reset by a technician with the proper scan tool. (You could purchase a scan tool from Peake Research that has access to the SRS in your car, this tool will give you the meaning of the engine codes and the ability to reset the Check Engine light, as well as read and reset the SRS codes.) I forget, but I think the price point for the Peake scan tool is about $150. There are better and cheaper ways to scan for OBD II codes, but these ways do not include the ability to reset the SRS light.
    Check Engine is the big red flag here. Unless you are a mechanic and/or able and willing to make repairs to your car, you should never buy a car with the check engine light on. In the People's Republic out here on the Left Coast they say that it is unlawful to sell a car with the Check Engine light on. The seller is required under the law to provide a car offered for sale with a current Smog Certificate, this means that the light must be off AND the car has passed the smog test. You can elect to buy a car with the light on, but you cannot transfer title until the car passes the smog test. I don't know that you have a smog test in Florida, but the idea is that the check engine light is a big deal on the Left Coast, and the buyer should not be saddled with the burden to make repairs before he can drive a car that he just purchased. You can, and should, scan the codes and understand why the light is on, then discount the value of the car for the expected repairs or demand that the seller make the repairs before you pay the asking price.
    Having said that, the car is 20 years old, so with 220k miles it was driven about 10,000 miles per year on average. This is not too bad.
    Aug 2016
    Western Pennsylvania
    1998 BMW 323is
    I won't try and talk you out if buying it, because I've bought much worse cars myself for much more money, but I will state a few facts that may help you with​your decision.
    In my own experience, Check engine lights on cars that are for sale almost always mean bad catalytic converters. Not a super big issue, but definitely an expensive one.
    220,000 miles is a long way for any car to go, but especially an unmaintained one.
    The damage in the front you described sounds like the result of a possible front end collision. If the car was wrecked, run, don't walk away.
    washington dc
    Avus Cosmos Calypso!
    "pristine" e36 m3s are more like $13k+. There are fewer and fewer of them around with every passing year. Likewise a "pristine" non-m car value is also on the rise but less so than the Ms.
    Unless you know your way around e36s better to look for something which is better maintained. Listen to JD's advice on the check engine light.
    Jun 2010
    NY
    1997 328i
    You really need to do a compression check on it. It's been neglected and could have a failed head.
    If the head is good, $2200. If the head is bad then $800.
    Jan 2014
    DFW
    '08 Acura TL Type S
    Quote Originally Posted by Tim Mc View Post
    Thanks.
    2017: no trouble lights, no dents, no rust, high miles M3/4/A is worth approx. $5000, maybe more if interior is MINT, like show-car spotless, which is rare AF. What you describe is $2500 tops if the interior's nice.
    In general about BMW:
    New/newer BMW = (money x money x money) x3, drive it all the time.
    Used/older BMW DIY = money + tools + time, drive some of the time and work on it some of the time which can be very rewarding for the mechanically inclined... but also means you need a second car/truck for daily driver.
    Used/older BMW take-to-independent-mechanic = money + money + time, drive some of the time and wait for it to get worked on some of the time, which is NEVER rewarding plus you still need a backup daily.
    We won't even discuss Used/older take to a BMW dealer... not recommended.
    Dec 2016
    vero beach, FL
    1997 328ic
    Quote Originally Posted by scooper View Post
    FL still has good amount of pristine cars at least body wise due to favorable climate and great roads, so finding one for 10k is relatively easy. Just a quick look brought this one https://miami.craigslist.org/brw/cto/6077839907.html
    AA tuned with 160k. Anybody recognize this here on here?
    m50 mani / AA c38-81 stage 2 / 12psi / AEM progressive w/m kit / stg3 SB endurance clutch + SS / 3.38 LSD / cdv + asc delete / stromung catback + cat delete / ebay coilovers + GC RSMs / square CSL wheels / ski-pass 8" sub
    Apr 2012
    Stuttgart, Germany
    1997 M3 / 5.3
    Folks, many thanks for reinforcing my thoughts.
    The shell is quite clean...two dents won't be able to be removed without body work.
    I'm confident it hasn't been in an accident other than a bumper respray.
    No service history...none. It does look well maintained until things began to spiral.
    I believe the car has been for sale for at least a year...guess I'm not the only one steering clear.
    I do like it as it is nearly completely stock.
    Again-thanks for the input...I now realize there is an M3 section-apologies.
    Apr 2012
    Stuttgart, Germany
    1997 M3 / 5.3
    To further close this thread out...and probably against better judgement...I bought the car.
    It will be a deliberate project with my son so investing time is expected.
    We plan to install a small LS engine and T56 to keep it interesting.
    Start of my build thread:
    https://www.bimmerforums.com/forum/s...9#post29724879
    Additionally, I actually printed this thread out and used it in my defense for negotiating. It helped...final price $3500.
    Thanks again for trying to talk me out of it! Some just don't listen!
    Jan 2006
    Durham, NC
    98M3/4/5 SpeedMiata
    You never said it was Estoril, did you?! That's +$3k! #bestM3colorever.
    Current:
    98 M3/4/5 Alpine/Magma
    05 MazdaSpeed Miata
    Sold:
    00 Honda VFR
    99 528iT M/T
    98 M3/4/5 Arctic/Dove
    94 R-package Miata
    89 Honda NT650
    87 325is turned SpecE30
    Jul 2016
    Chicago, Illinois
    are slow
    Quote Originally Posted by Ex36 View Post
    #bestcolorever.
    fixed
    Jun 2010
    NY
    1997 328i
    Wow! It's BEAUTIFUL
    Kirkland, WA
    2006 Toyota Tundra
    Oh please tell me that is just a sticker.
    Aug 2013
    1999 BMW M3 Coupe
    Doesn't sound like a sticker from his other thread. He's taking lacquer to it and scrubbing it off, slowly and painfully.
    And yes, it's horrid. If anyone is thinking about something like that, for the love of all that is holy use vinyl.
    Apr 2012
    Stuttgart, Germany
    1997 M3 / 5.3
    I wasn't aware the blue was sought after. I will say it pops still after 20 years (the sides anyways).
    Yes it was a painted on M3 across the hood. Certainly a big detractor that the fellow didn't seem to understand. But yes, it will come off with elbow grease, unfortunately they scuffed the hood to apply the paint so the finish is damaged. We plan on repainting the hood and roof (clear coat flaking).
    Should be fun!
    Kirkland, WA
    2006 Toyota Tundra
    Should be fun!
    I think most on the forum would agree that Estoril is probably the best, most popular and most valuable E36 M3 Color.
    Jan 2006
    Durham, NC
    98M3/4/5 SpeedMiata
    Why oh why couldn't he have just put a "Stay Classy" banner, in a cheesy font, across the windshield and been satisfied? That painted M3 now ranks #1 for dumbest aesthetic mod I've ever seen on one of our cars. And there are lots of pretty stupid ones....
    Current:
    05 MazdaSpeed Miata
    Sold:
    00 Honda VFR
    99 528iT M/T
    94 R-package Miata
    89 Honda NT650
    Feb 2012
    Birmingham, Alabama, USA
    1995 BMW M3
    I agree lol.
    I'm typically really tolerant of mods, even ones I don't like. But holy hell that is disgusting.
    Apr 2012
    Stuttgart, Germany
    1997 M3 / 5.3
    It has now been excised!
    A repaint will follow down the road for hood and roof.
    Jan 2006
    Durham, NC
    98M3/4/5 SpeedMiata
    Ahhhhhh, the car thanks you!
    Current:
    05 MazdaSpeed Miata
    Sold:
    00 Honda VFR
    99 528iT M/T
    94 R-package Miata
    89 Honda NT650
    May 2005
    Diamond Bar, CA
    97 M3/2/5
    Thank you for saving an e36 M3
    Current cars:
    87' Zinnorot 325is
    91' Alpine white 318is
    92' E30 Alpine white Mtechnic
    97' E36 Alpine white M3/2/5
  1. WTB: 1997 or 1998 E36 M3, 4 door AUTO.
    By 1996 300ZXTT in forum 3 series & Z Series
    Last Post: 11-19-2009, 12:49 AM
  2. M3 Auto Door locking question
    By HiStandards in forum 2001 - 2006 M3 (E46)
    Last Post: 08-06-2008, 06:01 AM
  3. FS: 1997 4-door M3 dakkar yellow
    By audidriver18 in forum BMW Cars For Sale / Wanted
    Last Post: 08-25-2003, 04:22 AM
  4. FS:1997 4 Door M3, salvage title
    By Revv Hard in forum BMW Cars For Sale / Wanted
    Last Post: 04-21-2003, 02:11 AM
  5. 1997/1998 auto m3?
    By RX7guy in forum 1992 - 1999 M3 (E36)
    Last Post: 12-31-2002, 12:06 PM
