BMW 335i Dinan Springs
Installed June 2015. Uninstalled (went to coil-overs due to shocks at end of life) March 2017. Springs are in very good shape, some small spots of surface rust. Includes used front sway bar links and all pads/shims shown.
Not compatible with x-drive vehicles.
From Dinan's website --- https://www.dinancars.com/product/d100-0926-dinan-performance-spring-set-for-bmw-e93-328i/
Dinan's Performance Spring set for the E90 335i provides greater control over body roll by virtue of carefully calibrated spring rates. Additionally, Dinan? lowers the vehicle for improved suspension geometry and an even more aggressive stance. The Dinan? springs are CNC wound with high tensile chrome silicon wire and shot peened for stress relief to last the life of the car. The increase in stiffness of the springs will reduce the rear suspension compression under acceleration and front suspension compression (or dive) under braking, giving your car a more controlled feel. The Dinan performance springs will also provide a noticeable improvement in grip, for high speed driving situations that will inspire confidence in your car's capabilities. The reduced body roll makes the steering more responsive to driver input and will be noticed at low speeds up to the top speed of the vehicle.
Benefits of the Dinan? Performance Spring Set for the E90 335i:
+ Increased spring rates
+ Vehicle lowered 1/2" in front and 0" in the rear
+ Preset to prevent spring sag
List Date: 4/7/2017
For more info, click here to view the original listing: BMW 335i Dinan Springs
SOLD
