eBMWParts
Results 1 to 3 of 3
Thread: strange clicking noise/wheel bearing?
    Oct 2015
    Hanford, Ca
    2002 BMW M3 coupe
    Sorry if this is posted in the wrong spot, but I'm getting this bearing noise. Like not a humming noise, but a clicking noise. I'm positive it's coming from the right side of the car, and it's a continue clicking. It's not an engine tick because it gets louder with speed, not with RPM's, I think it's my right rear. My brake pads have a lot of low and my rotors aren't warped. So I'm not sure, I think it's a wheel bearing, but usually wheel bearings hum and not click, so if any of you guys would be generous enough to chime in on this.
    I'm not sure how to post a video yet, so here's a link of the sound I'm getting that I posted to YouTube.
    https://youtu.be/0XVhexUtf3g
    Dec 2013
    Chicagoland area
    EXOTICS
    Check for bent brake backing plate.(AKA dust shield)
    Aug 2013
    1999 BMW M3 Coupe
    Check your caliper guide pins and bushings, especially if they are solid. I recently had a very similar issue after one was seized on a slightly deformed pin and the pad was dragging.
    Also, if a pad is dragging like this you'll be able to tell by touching the rotors after driving for a bit. One will be much hotter than the others. There will likely be more brake dust as well.
    Also check for any clearance issues, like brake hoses, sensor wires, fender liners, and rotor dust shields. If a pad isn't dragging and it's not just pad rattle, then something is likely getting hit as one of your wheels spins.
  1. Strange whining noise, wheel bearing? (video link)
    By Sean0987 in forum 1991 - 1999 (E36)
    Last Post: 09-25-2012, 10:47 PM
  2. Help! Strange clicking noise when cornering left
    By JT-KGY in forum Track, Auto-X & Drag Racing sponsored by Bimmerparts.com
    Last Post: 04-21-2006, 09:54 AM
  3. Strange "clicking" noise coming from the back?
    By desertzoni in forum 1995 - 2001 (E38)
    Last Post: 04-08-2006, 10:09 AM
  4. Help! Strange clicking noise when cornering left
    By JT-KGY in forum 1992 - 1999 M3 (E36)
    Last Post: 03-29-2004, 02:41 AM
  5. Strange "clicking" noise ???
    By blackE38 in forum 1995 - 2001 (E38)
    Last Post: 02-25-2004, 03:10 PM
