Results 1 to 5 of 5
Thread: Coupe side mirrors problems
    Apr 2017
    Bulgaria
    330ci
    Hi all. Driver side mirror adjustment not work at all. Passenger side mirror tilt up (instead down) when I put in reverse. I have electric seats with memory. What could cause the problem and how to fix it ?
    May 2010
    Honolulu, Hawaii
    '73 E9, '94 E34, '02 E46
    I suggest that the driver's side mirror wiring is disconnected at the mirror or the switch. The outside mirror casing comes off, have a look inside and see what you see. I think (not having done this) you pry the switch out.
    Can you adjust the right side mirror? Sometimes the switch gets cr*p spilled on it and gums up; in that case several doses of contact cleaner while working the switch can restore function.
    Charlie
    Apr 2017
    Bulgaria
    330ci
    Yes I can adjust the right side mirror, but it goes UP when put in reverse. I will check the cables of left side mirror.
    Jul 2011
    Arlington, VA
    2018 BMW M240i
    As I recall the control signals for the passenger mirror go through the control module for the driver’s mirror. That is, the mirrors are daisy chained. I’d fix the driver’s mirror and see what that does to the passenger mirror.
    Apr 2017
    Bulgaria
    330ci
    Quote Originally Posted by MarcoZandrini View Post
    Thanks for advice. I will check the driver's mirror. I think the electric motors are blown out.
  1. FS: OEM E36 M3 Coupe Side Mirrors
    By 94calypsored in forum Exterior Lighting & Body Parts
    Last Post: 06-16-2007, 10:54 PM
  2. Side Mirror Problem
    By MPower204 in forum 1992 - 1999 M3 (E36)
    Last Post: 06-15-2007, 01:41 PM
  3. Side mirror problem
    By TRogers in forum 1999 - 2006 (E46)
    Last Post: 02-21-2007, 07:40 PM
  4. WTB: M Roadster/Coupe side mirrors
    By bimmerZ5 in forum BMW Parts Wanted
    Last Post: 01-04-2005, 02:43 AM
  5. FS: E36 White Coupe Side Mirrors (325, 328)
    By DeanB in forum BMW Parts For Sale
    Last Post: 01-27-2004, 05:49 PM
