Page 7 of 9 FirstFirst 123456789 LastLast
Results 151 to 175 of 202
Thread: Upper and Lower M Console Trim redesign and development! Taking over a dead thread.
  1. #151
    TX
    97 M3/4/5, MCS
    Quote Originally Posted by Venom13132 View Post
    those wheels look pretty close even though the car is not an M that they have modeled. minimum you can buy is 25 credits. that print is 4 credits and the credits are €20.00 so whatever that is in USD. If I didn't have to buy a minimum of 25 credits I would probably download that just to have the cad files.
    The 25 credits are $24 total. Probably not going to break the bank.
  2. #152
    Indianapolis
    F30 328d X-Drive
    Quote Originally Posted by MarketMaster View Post
    yeah I don't want those prints that badly. Bimmerbreaker may though. I'd rather spend $24 on beer ill get more enjoyment out of that.
  3. #153
    Are those a 3d file or a vector image?
    If I buy it can someone separate just the wheel for me?
  4. #154
    Jun 2005
    Chicagloland
    99 Estoril Blue M Coupe
    Quote Originally Posted by BimmerBreaker View Post
    Some OEM colors are still avaiable and for right now getting one of those is the best bet and only sure way to get one
    Sort of on topic for 3D files... I'm making some "Roadstar" keychains, like these, but for Roadstar wheels
    If anyone has a 3d scan of a Roadstar, I can reward you with some free keychains (not a lot I know but hey...) or work something else out?
    Otherwise we will be basing the design off just a bunch of pictures and I'm not entirely sure I trust that
    The dude who made the 3pc roadstars probably would. Icon forged?
  5. #155
    Quote Originally Posted by chemicalviper View Post
    I thought that too, never asked him because I can't imagine he'd give it out.
    I don't have the means to make wheels though (and I'm not stupid enough to try, I know for custom designed wheels, $1100/wheel is a steal) so maybe I can get in touch
    PRICE CUT on ALL FABRICS
  6. #156
    TX
    97 M3/4/5, MCS
    again, i am not SURE those are the wheels you are looking for so there is a RISK if you buy them. Here are the formats:
    • Adobe Illustrator (.ai)
    • Encapsulated Postscript (.eps)
    • Portable Document Format (.pdf)
    • Scalable Vector Graphics (.svg)
    • AutoCAD (.dwg)
    • Drawing Exchange Format (.dxf)
    I know I can work in .dwg and .dxf. It "should" have everything as a separate part that would make it easy to just pull the wheel out. Again, these are assumptions and risk.
  7. #157
    I will buy it this weekend if nobody else can help me before then
    Anybody interested in a keychain? They will be metal. Thinking like $10 shipped for em
  8. #158
    Indianapolis
    F30 328d X-Drive
    I can work with most of those file types here at work. So I would be happy to work with them for you. Mainly the .dwg and .dxf file types
  9. #159
    San Diego, CA
    1999 BMW M Coupe
    Quote Originally Posted by TommyMaddox View Post
    I'll get that model sorted asap, what's the dimensions of your double din and bezel?
    Tommy, I can get these made on. Professional HP MJF 3D printer. We can print as many as we can stuff into a 15”x11.5”x15” build volume. If you send me a step or iges file I can get it going.
    1999 M Coupe
  10. #160
    Aug 2016
    Spring TX, USA
    2000 BMW Z3 2.3
    Quote Originally Posted by tommy1394 View Post
    I've been having issues with the material removal for the AC controls. I think I may scan the AC interface and just to a subtract material command and try to fill in enough material so that there is something to drill into in order to mount the AC bezel, which uses a combination of clips and screws now.
  11. #161
    May 2016
    Buffalo
    08 R32, 11 128i
    Is it possible to convert these scans to a solid part? I would like to add some material in to reinforce the weak points. I also wouldnt mind attempting to print it as two pieces on my replicator.
  12. #162
    I've posted a link to the downloadable grabcad file in the OP
    Would really love for someone to clean it up (Venom said it needed a little tweaking) and maybe produce and release a version with the cig lighter delete and extra slot for switch. Deleting the cig lighter and replacing it with an extra switch slot and then evening the gaps between the switches would strengthen it by widening the gap (slightly) between buttons. It would also provide more area for reinforcement ribbing to be applied to the underside.
  13. #163
    Aug 2016
    Spring TX, USA
    2000 BMW Z3 2.3
    AC Bezel is taking shape nicely. I will use this as a cutting element to remove the material needed to mount it in the lower portion of the panel, as well as a block to build material up to in order to supply reinforced mounting points for it.
  14. #164
    Indianapolis
    F30 328d X-Drive
    I just purchased an upper trim piece off ebay that's not broken. I will try to get a scan of it as soon as I can. Will likely have to come in to work on a day off to get it scanned in.
  15. #165
    Aug 2016
    Spring TX, USA
    2000 BMW Z3 2.3
    That's great news, I was not very happy with the scan quality of mine. Maybe I can work on modifying the lower trim while you scan the upper trim.
  16. #166
    Indianapolis
    F30 328d X-Drive
    https://www.amazon.com/dp/B073VJBQ79...NVRBL0W4&psc=0
    considering buying this printer. Build volume is the biggest issue with these parts. This one is 19.6x19.6x19.6" build area (500x500x500mm). I think the longest dimension on the lower console is around 11" or so (cant remember exactly).
    I would guess printing in ABS would be best for these?
    edit* just got an email that my upper trim showed up. I am going to see if I can get access to the 3D scanner tomorrow (tomorrow is an off day where I work so I should be able to use it)
  17. #167
    Won't a printer with that resolution require a lot of finishing work, which would then mean a lot of variances in final appearance as well as fit and finish?
  18. #168
    Indianapolis
    F30 328d X-Drive
    no idea. I am new to printers. Not sure what resolution I would need.
  19. #169
    Mar 2003
    Akron, Ohio
    M3 Saloon, Z3 3.0 Coupe
  20. #170
    Tallahassee
    1998 Z3 M Roadster.
    I have access to several higher resolution printers.
    Would be happy to print some test pieces if someone sends me a file
    Also have access to a Steriolithograohic system. That may be even better.
  21. #171
    Indianapolis
    F30 328d X-Drive
    Quote Originally Posted by magnetchief View Post
    https://grabcad.com/library/bmw-z3-m...console-trim-1
    link to the lower trim files. I need to find some free time to stay after work or come into work on a day off to scan the upper trim.
  22. #172
    TX
    97 M3/4/5, MCS
    I think SLA would be a requirement. FDM just won't be able to produce a smooth enough product and when having to clean up the part will lose tolerance. imo of course.
  23. #173
    I have been told SLA produces a brittle final product, which would be unsuitable for this type of trim piece
    3D printing seems genius until you realize all the limitations :/
  24. #174
    TX
    97 M3/4/5, MCS
    Just got it quoted in SLA. It would be $215 for an SLA sample that is finished. It would not be painted and would come in a rather clear color.
    There is not much flex in SLA, that is true but if you aren't removing this all the time, I don't think it should be an issue. We typically print small exterior truck parts.
    The optimal process and material would be injection molding but then the tooling comes in at a higher cost.
  25. #175
    Indianapolis
    F30 328d X-Drive
    That seems a bit high. You can still buy these for close to that price new from stores like ECS tuning. https://www.ecstuning.com/b-genuine-...e/51162491400/
  1. E60,E61 FS: BNIB Front Upper and Lower Control arms with bushings and ball joints.
    By Willicuddy in forum Suspensions, Springs & Shocks
    Last Post: 05-12-2013, 06:49 PM
  2. E39 front edge lower arch liner trim (sport and non sport)
    By cluster in forum 1996 - 2003 (E39)
    Last Post: 03-02-2012, 02:06 PM
  3. E31 E31 Lower dash/console trim panels - silvergray
    By olinjohnston in forum Exterior Lighting & Body Parts
    Last Post: 05-22-2011, 06:31 PM
  4. E46 Upper and Lower Steering Wheel Trim Wrapped in Carbon Fiber.
    By Zubehor in forum Interior Lighting & Body Parts
    Last Post: 05-08-2011, 05:36 PM
  5. Feeler: Any interest in my Factory Rollhoops and rear center console/trim
    By chaswr7 in forum 1996 - 2002 Z3 (E36/7, E36/8)
    Last Post: 03-13-2010, 09:37 AM
