Page 5 of 9 FirstFirst 123456789 LastLast
Results 101 to 125 of 202
Thread: Upper and Lower M Console Trim redesign and development! Taking over a dead thread.
  1. #101
    Aug 2016
    Spring TX, USA
    2000 BMW Z3 2.3
    Fresh 3D print (FDM ABS) of the lower console that Venom13132 scanned. Prior to cleaning with acetone/MEK and some filling, sanding, and paint.
  2. #102
    Certainly looks like a center console. Nice work
    PRICE CUT on ALL FABRICS
  3. #103
    Indianapolis
    F30 328d X-Drive
    Quote Originally Posted by TommyMaddox View Post
    Very cool! Nice work
  4. #104
    Aug 2016
    Spring TX, USA
    2000 BMW Z3 2.3
    Quote Originally Posted by Venom13132 View Post
    You did all the hard work! I should be able to find the time soon to finish modeling the double din version I've been working on.
  5. #105
    Sep 2015
    Chicago
    2000 Z3 M Coupe
    Put me down for two of those! One for now and one for backup.
  6. #106
    San Diego, CA
    1999 BMW M Coupe
    Attachment 605595Attachment 605596Attachment 605597
    The first picture shows the mixed surface/solid modified entity created from the automatically surfaced body that was obtained from the meshed scan data. This consisted of filling the AC holes, filling the lower gauge holes, and enlarging the stereo and stereo bezel opening to the 2 din size. Next the AC holes were relocated to the former location of the gauge holes (with the correct diameter and spacing). This solid-surface mixed entity was then reconverted into a mesh (purple), and the two meshes in the 3rd picture will be intersected and merged to produce the correct modified 2 din panel, and then cleaned up for 3d printing.
    Of course I will still have to make some test fit modifications to accomodate the AC controls, as the support ribs on the back will interfere with flush mounting.
    Now we just need someone to make some extended cables for the hvac knobs
    1999 M Coupe
  7. #107
    May 2015
    Springfield Il
    '97 Z3
    Would you be able to make one without the accessory buttons for a non-M? If so about how much would one cost? I love the look the shifter trim ring gives the interior.
  8. #108
    Feb 2014
    allentown
    99 Z3MC/00' 2.8 roady
    Looks great! How long did it take you to make it?
  9. #109
    Indianapolis
    F30 328d X-Drive
    Quote Originally Posted by nthor71783 View Post
    the non-M trim is completely different. I would need to have one to scan in to make a point cloud of it.
  10. #110
    TX
    97 M3/4/5, MCS
    what scanner did you use to scan it? I've been looking at the Artec eva and spider.
  11. #111
    Kent, Ohio
    1998 M Roadster
    I'm not familiar with 3D printing--is that as good of a finish as it can produce due to the nature of the process, or is that something that can be improved with tweaking?
  12. #112
    birmingham,al
    2001 3.0 Z-3 RD'STER
    Ahhhh very good progress. Looking forward to seeing this panel after it's cleaned up and painted. Have you given thought to a selling price and can they be massed produced or by special order only?
  13. #113
    Sep 2013
    Fort Lauderdale, FL
    e30 m3, 99 M Roady
    impressive!
  14. #114
    Quote Originally Posted by Mr Bingley View Post
    Depends on the printer but that ones not too bad. They work by melting plastic and extruding it so there often times becomes a tradeoff between dots per inch and time it makes to produce the unit (and cost)
    They then have to be finished by hand
  15. #115
    Denver, Colorado
    MRster / Z4 M4i / X5 M50
    I found this article with may help explain the process ...
    https://www.fictiv.com/hwg/fabricate...-printed-parts
    2002 M Roadster, Steel Gray Metailic, Gray Nappa Leather, Black Soft Top, Steel Gray Metailic Hard Top, TC Kline Double Adj Shocks with H&R Springs, Stromung Exhaust, SSR Type C Wheels. Looking for a new home.
    2022 Z4 M40i, Misano Blue Metallic, Prem Pkg, Driver Assistance Pkg
    2023 X5 M50, Phytonic Blue, Black Extended Merion Leather, Driving Asst Pro Pkg, Park Asst Pkg, Exec Pkg, Climate Comfort Pkg.
  16. #116
    NYC
    1999 M-Coupe, 2013 S60RD
    Wow - looks amazing - if we can manage to color-match the existing interiors that would be incredible.
  17. #117
    Indianapolis
    F30 328d X-Drive
    Quote Originally Posted by MarketMaster View Post
    I used an Atos III triple blue light scanner from GOM. Its around a $300,000 system we have at work.
  18. #118
    TX
    97 M3/4/5, MCS
    Would almost kill (literally) for a scanner that nice. Do you contract?
  19. #119
    Aug 2008
    Australia
    BMW Z3
    Hey guys .
    So are these files able to be downloaded now that they have been tweaked?
  20. #120
    Indianapolis
    F30 328d X-Drive
    I work for Rolls-Royce Corp (not the cars, that is BMW) so cant really contract out. I can moonlight a little on my own time. I do know an individual that has his own scanner and runs a private business with it. No idea what his rates are.
    Quote Originally Posted by Sr20Tz3 View Post
    Hey guys .
    the files have been on GrabCad for some time now.
  21. #121
    Apr 2014
    Seattle
    I know almost nothing about 3d printing or CNC machining, so this is probably a dumb question, but... Would it be possible to take the files produced from scanning and use a CNC mill? Rather than printing?
  22. #122
    Quote Originally Posted by JamieOurada View Post
    Depends on the file. CNCing is usually cost prohibitive though for stuff like this.
    Would an SLA printer work for these? Way higher resolution but the plastic is not as strong
  23. #123
    TX
    97 M3/4/5, MCS
    Quote Originally Posted by BimmerBreaker View Post
    Depends on resin. 3d Systems will quote any project that you have with many resin options.
    if someone really wanted to make it more cost efficient, you can always get some soft tooling. That requires investment though.
  24. #124
    mherington is offline Passing Gas... BMW CCA Member
    Duluth, GA USA
    1999 Z3 M Roadster
    What about printing (or milling) a high-res master, then finding a shop that can take that and do a run of conventional injection molded units?
    Sent from my iPad using Tapatalk
  25. #125
    Aug 2016
    Spring TX, USA
    2000 BMW Z3 2.3
    This can be done, as I can just make the mold negatives digitally from the stl file, and have someone modify the negatives into injection mold tooling, but this will realistically need to be a crowd funding effort as it will probably cost $5000-$10000 at least to get a production run going for this part. The upside is that we would have cheap consoles and would be able to see if this is a great method of reproducing NLA and/or expensive plastic bits for long-term ownership purposes.
  1. E60,E61 FS: BNIB Front Upper and Lower Control arms with bushings and ball joints.
    By Willicuddy in forum Suspensions, Springs & Shocks
    Last Post: 05-12-2013, 06:49 PM
  2. E39 front edge lower arch liner trim (sport and non sport)
    By cluster in forum 1996 - 2003 (E39)
    Last Post: 03-02-2012, 02:06 PM
  3. E31 E31 Lower dash/console trim panels - silvergray
    By olinjohnston in forum Exterior Lighting & Body Parts
    Last Post: 05-22-2011, 06:31 PM
  4. E46 Upper and Lower Steering Wheel Trim Wrapped in Carbon Fiber.
    By Zubehor in forum Interior Lighting & Body Parts
    Last Post: 05-08-2011, 05:36 PM
  5. Feeler: Any interest in my Factory Rollhoops and rear center console/trim
    By chaswr7 in forum 1996 - 2002 Z3 (E36/7, E36/8)
    Last Post: 03-13-2010, 09:37 AM
