Results 1 to 4 of 4
Thread: Transmission problem?!
    Apr 2017
    Atlanta, Ga
    1992 BMW 735il
    I have a 1992 735il and I believe my transmission is giving way. It started shifting odd once I replaced my shifter cable and now, RPM will rise but car would still have no power. I checked the fluids, they're good. What's next? Is it my transmission or possibly an electrical problem
    Jan 2005
    Japan
    11/88 E32 750iL+98 E36M3
    Did you check the fluid level the proper way with engine running and AC on? Here is the detailed procedure http://www.europeantransmissions.com...MWtechinfo.htm
    What means fluids are good? Level, color, smell?
    Changed already the transmission filter? Cleaned the valve body? There is a filter inside the valve body, that can be blocked https://www.bimmerforums.com/forum/s...hifting-solved
    Do you see the selected gear and mode in the check control in the cluster? If not, clean the shift selector contacts http://www.nmia.com/~dgnrg/page_13.htm
    does it work when you select R, D, 3-2-1 or all all selected gears not working, that would be strange.
    Do you see in the cluster the selected gear = same what is shown in the shift indicator under the gear handle?
    Did you install the shifter cable correct?
    https://www.bmwtechinfo.com/repair/m...es/4810390.jpg
    https://www.bmwtechinfo.com/repair/m...es/4810391.jpg
    https://www.bmwtechinfo.com/repair/m...es/4810392.jpg
    Apr 2019
    San Diego
    1988 735il
    Have a 1988 735il. Trans won't go into 4th gear. Any thoughts or suggestions?
    Jan 2005
    Japan
    please answer the questions in my post # 2.
    4HP22 repair manual says: gear change functions in cold or warm state faulty:
    change 1-2/2-1 = governor dirty
    change 1-2 = brake C' and/or C faulty
    change 2-3/3-2 = governor dirty, shift valve 2-3 sticking
    change 2-3 = clutch B faulty
    change 3-4/4-3 = governor dirty, shift valve 3-4 sticking
    change 3-4 = brake F defective
    I would check first all these things and clean the valve body.
  1. 1994 - 740i Transmission Problem
    By Alan Nelson in forum 1988 - 1994 (E32)
    Last Post: 05-03-2008, 11:59 AM
  2. transmission problems :-(
    By prolepsis in forum 1983 - 1991 (E30)
    Last Post: 06-19-2002, 03:47 PM
  3. Getrag transmission problems
    By Bosch-Intern in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 05-03-2002, 07:42 PM
  4. Auto transmission problems(please help)
    By NWG in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 01-17-2002, 10:38 AM
  5. Transmission Problem? (yes or no)LONG
    By C///M3 in forum 1992 - 1999 M3 (E36)
    Last Post: 07-16-2001, 01:07 PM
