Results 1 to 9 of 9
Thread: Gas Cap Check Engine Light
    Dec 2009
    Lancaster, PA
    2003 BMW Z4 Roasdter
    Recently a light popped up on the dash that said gas gap loose. I tightened it and shortly after a service engine soon light came up. After a week af looking at that I went to Auto Zone and the guy read the code and said it is just a gas cap notification and it should go off after 200 miles. It doesn't seem to be going off so I'm wondering if I need a new gas cap. Do the seals go bad after a while? I have a 2003 Z4 Roasdster with 32000 miles on it. When I bought the car 2.5 months ago that gas cap was on so freekin tight I needed a pump pliers to remove it. Any input would be greatly appreciated.
    Ken
    Fleet:
    2003 BMW Z4 Roadster 3.0i
    2013 Jeep JK Wrangler Unlimited
    Feb 2008
    Pac.NW
    '03 Z4, '85 Subaru Wagon, '87 Suzuki Savage LS650
    Not to alarm you, but my gas cap light was the first sign that my instrument cluster was failing. This happened while under warranty so the car was still relatively new.
    Hopefully you just have a faulty sensor.
    Not so much a signature as a cry for help.
    Hold on, saw this in a cartoon once...think I can pull it off.
    Dec 2013
    Chicagoland area
    EXOTICS
    The cap shouldn't require more than a firm pushdown and twist motion.
    Purchase a new Genuine BMW replacement cap,It is 17yrs old after all, and the rubber seal may have deteriorated.
    Feb 2009
    harrisburg pa
    1994 325ic, 2012 328ic,
    I know this is old but have similar problem. Wife had fuel cap warning come up a couple of time. Reset the cap 2x but now have service engine soon light. Advance Auto code checked said it was an evap code. Didn't give a number. As usual Murphy hit and I cracked the screen on my Foxwell NT520. Will a bad cap cause a constant Service Engine Soon light to stay on?
    Dec 2013
    Chicagoland area
    EXOTICS
    Yes, due to a bad cap causing a leak in the fuel evap system, triggering an OBD2 emissions fault, causing a SES light to illuminate.
    Feb 2009
    harrisburg pa
    Thanks. Wife just said the cap light came on once before 2 weeks ago. 83k so a new cap is a fair bet.
    Jul 2018
    NE Ohio
    2007 Z4 3.0si Roadster
    I had to but a new one to get the light to go out. Dealership had one in stock. My light went out after a day or so of driving.
    Dec 2013
    Chicagoland area
    EXOTICS
    Glad it was a cheap,easy fix.
    Feb 2009
    harrisburg pa
    I think the wife just didn't seat it correctly. Light went out and hasn't been back.
  1. Fuel Cap & Check Engine Light
    By jaramill in forum 1992 - 1999 M3 (E36)
    Last Post: 05-10-2016, 03:50 PM
  2. Check gas cap>check engine soon...?
    By Flycaster in forum 1999 - 2006 (E46)
    Last Post: 07-26-2010, 03:22 PM
  3. Gas Cap and Check Engine Lights
    By rsott59 in forum MINI (Cooper & Cooper S)
    Last Post: 01-09-2008, 07:59 PM
  4. Gas cap and check engine light....
    By PwrdbyM in forum 1996 - 2002 Z3 (E36/7, E36/8)
    Last Post: 10-09-2007, 04:58 PM
  5. Gas cap & Check Engine Light
    By LoganBerry in forum 1992 - 1999 M3 (E36)
    Last Post: 05-02-2005, 04:43 PM
