Wonder if anyone here successfully uses INPA to run analysis and register battery on 2013 X5 xDrive35i? I purchased a K-DCAN cable from ebay with software. When I installed it on my laptop which has windows XP professional on it, my model did not show up in the "engine" section. Have tried to install a different version of INPA which did show "MEVD172 for N55" under "engine", but showed an error when I clicked it, an error popped up. Really frustrated. Anyone can help? Thank you.
Good day!!
You need to make sure you have the correct SP-Daten for your model and year... I have INPA, NCS Expert, ISTA/P, dedicated laptop and the ICOM to program all my E-53's... You probably could get your set-up to work using the MEVD data you found, but I'm guessing you did not modify the cable... You need to open it up and solder the pins 7 and 8... That should work...
Cheers!!
