I'm having issues getting the sap monitor going.
Today I used easydiag 2.0+ and made a graph.
https://drive.google.com/file/d/0B2h...w?usp=drivesdk
The app doesn't seem to start recording until the engine starts but I'll let you know now, prior to starting the o2 sensors were both solid 0.43
Here is a video I made of the values so you can see the sap activation and other values.
https://youtu.be/9_PKN3IfAVQ
So basically b1s1 is 0v while the sap is active.
Here's a repair made recently that may be worth mentioning.
I was having lean codes and repaired a bunch of hoses. Bank 2 lean remained. I then switched my precat o2 sensors and it followed. So b2 was initially bad, so it followed to b1. So obviously I just replace the bad sensor. I'm going to switch them for tomorrow's cold start and see what the results are.
Any thoughts at this point?
Ok so I switched the sensors and it followed. So I was certain it was a bad sensor. Today I replaced it and the new sensor is doing the same thing but maybe not quite as bad.
Here's a video of the results https://youtu.be/yLf1aQiPpUs
I'm a little thrown off by this. These are bosch sensors. Why is this happening with two new sensors yet the old yellow one is strong as an ox.
