Results 1 to 11 of 11
Thread: WINKFP Daten Update - Errors and force closes
    Apr 2008
    Brooklyn, NY
    2001 BMW 330i
    Tried to manually update (PDF Attached) as well as used the BMW coding tool (http://www.bmwcoding.com/showthread....MW-Coding-Tool) to update the daten files for winkfp.
    I can't get winkfp to properly open.
    CoapiKfInit: Initialization error!
    Tried to open the following files with wordpad from what I've read should fix it but has not.
    C:\EC-APPS\NFS\DATA\gdaten
    What other steps I need to review to get it to begin working again?
    RESOLVED:
    You have to use wordpad to open and save the following files:
    HISTORIE.BSU
    NPV.DAT
    PRGIFSEL.DAT
    SGIDC.AS2
    SGIDD.AS2
    Attached Files Attached Files
    Jul 2004
    Houston, TX
    36 Cylinders
    Use wordpad to open historie.bsu and save it as same file. (Just open and save as historie.bsu, that's it, don't change anything).
    Repeat with npv.dat and prgifsel.dat as well.
    -Abel
    - 2000 Z3: Many Mods.
    - 1999 S52 Estoril M Coupe
    - 2016 Mini Cooper S
    Jul 2004
    Houston, TX
    36 Cylinders
    I hope you know how to fix the .AS2 for the extra long lines that cause errors too.
    -Abel
    Sep 2003
    Birmingham, UK
    BMW 850 and E55 AMG
    Rightclick on some of those files, and check they don't have the crappy "this file might have come from a different computer" message, you'd see an unblock at the bottom of the properties tab.
    Giftschrank Projekt
    Apr 2008
    Brooklyn, NY
    2001 BMW 330i
    I didn't open historie.bsu. Doin g so fixed the issue. Thanks
    I used the BMW Coding tool. I assume that it commented out the long lines automatically
    Feb 2019
    Granite Falls, NC, USA
    2006 Z4 3.0i
    An update to an old thread here.
    I am new to this type of work and just installed standard tools through bimmergeeks.
    I just got the same error message as the OP and I saw he opened and saved:
    HISTORIE.BSU
    NPV.DAT
    PRGIFSEL.DAT
    SGIDC.AS2
    SGIDD.AS2
    I found the files, opened and saved, but no improvement.
    so then I saw where the OP found those files:
    and that is not where I found those same files.
    I found them here:
    C:\EDIABAS\Bin\Server\data\gdaten
    So, i just copied and pasted them where the OP had called them out and now my WINKFP opens up as I suppose is normal.
    I haven't used the software, but it does atleast open now where it did not before.
    Old thread I know, but thanks for the help!
    Mar 2008
    Costa Rica
    VW
    Hi:
    I update with bmwcodingtool
    Can you help me to fix error with .as2 file ?
    Sep 2008
    Fort Smith, Arkansas
    '99 328i, '02 X5, '07 Z4
    Quote Originally Posted by elecauto View Post
    Hi:
    How do you update? I am having same issue and the above did not help.
    1999 328i, 2002 X5, 2007 Z4.......
    Nov 2020
    East Tenn
    R52
    Find and Edit C:\EC-APPS\NFS\BIN\Winkfpt.ini
    The correct version looks like this:
    KOMFORT_MIT_AIF=OFF
    ; Trace
    API_TRACE=0
    IFH_TRACE=0
    ; ACHTUNG bei Änderung von CabdFormat muß auch im File ..\CFGdat\coapi.ini
    ; entsprechend CabdFormat geändert werden.
    CabdFormat=IPO
    ; IPS --> PABD Quelle
    ; IPO --> Übersetzte PABD
    ; COM --> Compilieren der PABD
    SPRACHE=eng
    LastWDPImportPath=C:\Users\DELL\Desktop\E60\data
    PROGRAMM_ERZWINGEN=OFF
    BSU_ZULASSEN=OFF
    ANZEIGE_KERNFUNKTION=ON
    ErrorLogPath=.\
    ExpertKonfPath=C:\Diagprog
    KomfortKonfPath=C:\NFS-Backup
    CoapiSearchPath=C:\EDIABAS\Bin\Server <--------------------------- this used to be ".." on mine and now it works
    [HW-Interface]
    K-Line / ADS=ADS
    K-Line / EDIC=EDIC
    K-Line / OBD=STD:OBD
    CAN / EDIC=EDICC
    CAN / Vector=STD:CAN
    Most / Optolyzer=STD:MOSTO
    Most / PC-Karte=STD:MOSTP
    Funk / MDA=STD:FUNK
    Ethernet / ENET=ENET
    [Expert-Modus-Konfiguration]
    KF_HW_INTERFACE=
    KF_DIAG_PROT=BMW-FAST
    KF_PSGBD=08flash.PRG
    KF_PABD=
    KF_SG_ADR=18
    KF_DATEN_DATEI=A7564227.0da
    KF_PROGRAMM_DATEI=7563275A.0pa
    KF_HW_INTERFACE_UNIT=
    KF_NAAB_DATEI=
    Jan 2021
    Austin, Texas, USA
    2005 BMW M3 Coupe
    For me, what ended up fixing my issue was when I went to search for the files in C:\EC-APPS\NFS\DATA\gdaten, my gdaten file was completely absent. Instead, it was located in the C:\EDIABAS\Bin\Server\data\gdaten location.
    Like sickwayne77 did, I had to copy the files from EDIABAS and paste them into the EC-APPS location. I just wanted to clarify though, I had to completely copy the whole gdaten file and paste it with all of the subfiles inside from the EDIABAS location. Just a heads up, as that is what fixed my error.
    Jul 2021
    Georgia
    1989 BMW e30 2-door
    had the same issue, updating sp daten via bmwcodingtool helped a lot
  1. WinKFP help update DME errors
    By e39touring1980 in forum Diagnostic Software
    Last Post: 08-19-2014, 10:55 AM
  2. Updates, questions and spam...
    By Hipendicular M in forum 1996 - 2002 Z3 (E36/7, E36/8)
    Last Post: 03-18-2004, 01:40 PM
  3. Feeler: GB on HID (Phillips bulbs and ballast) *CLOSED*
    By OxfordM3 in forum Group Purchases & Supporting Vendor Specials presented by eBay
    Last Post: 07-10-2003, 03:31 AM
  4. @A NEW KILL AND A CLOSE F@@CKIN CALL!! ( a little long!....)
    By 232is PoWeR in forum General BMW and Automotive Discussion sponsored by Intercity Lines
    Last Post: 08-01-2001, 10:19 AM
