Page 2 of 2 FirstFirst 12
Results 26 to 33 of 33
Thread: Continued M60 problems: hesitation/rough idle
  1. #26
    Philsdelphia
    1986 e24 635csi, 1999 Saab 93, 1992 Saab 9000 turb
    Quote Originally Posted by XAlt View Post
    Step 1 in E38 multi-misfire diagnosis: cats cats cats cats
    Somebody spent 20k fixing literally everything on his beloved 740, cats were bad even though they tested good.
    Alright....feeling more confident with every post from you guys.....will post again post cat removal.
    Sent from my VS995 using Tapatalk
  2. #27
    Philsdelphia
    Quote Originally Posted by danieljames View Post
    Cats cut and emptied. Car runs smooth and revs freely. Fixed. Passenger pre cat had collapsed into the main cat which was subsequently blocked. This caused the passenger bank of cylinders to shut down.
  3. #28
    Congrats, man! Glad that fixed it.
  4. #29
    May 2017
    Perth, Western Australia
    09/90 E34 525i (M50)
    Yeah, people need to look at cat converters more. In my aussie ford falcon my cat blocked up. It ran fine when cold but when warm it killed power and fuel economy. Also it's right next to the auto gearbox and I'm pretty sure it ruined a gearbox due to heat, even the replacement g/b runs terrible on warm days/long drives and I think the cat was cooking the repaired g/b. When the repaired g/b was cool, and the exhaust/cat was cool everything ran great, engine power and g/b shifting right. When exhaust hot, engine sucked, g/b sucked.
    When a car runs terrible and it's not spark and fuel, look at cat converters. It's a shame there's no easy way to check them without cutting them out and visually inspecting
  5. #30
    Philsdelphia
    Quote Originally Posted by fo3 View Post
    True true my Aussie friend in Gondwana land!! You have an XB!?!?
    I'm originally from NZ and have settled now in Pennsylvania.
    So your running hx of the falcon is similar to mine, but heres something you are missing. I discovered this closed loop open loop computer thing the cars do on start up. Basically a rich run environment and long flames going into the cat to heat them up. My car as yours did run fine for the first few minutes, that would be in the closed loop not taking signal from the cat in the warm up cycle......Funnily enough the right amount of time for fools like you and me to think all the tinkering on everything else had fixed the problem and we drive happily for those precious few moments. Then...........going into open loop the car "see's" the bad signal from the cat in combination with the back pressure and whamo!!! Shut down of the the bank of cylinders with the corresponding bad cat.
    I am so happy now and kinda stupid feeling for not doing this 5 months ago.
    Attached a couple pics of my M60 installed and the cat job and my car parked outside the house ready to cruise, wife and two kids in tow.24781.jpeg
  6. #31
    Oct 2014
    Prescott, Az
    '95 540i/6
    When I cut out the cats on my 540 for the "Off Road" exhaust system the cats came out in pieces. Including a big chunk of cat rattling in the rear muffler
  7. #32
    Well I guess I'll factor in a yearly cat change into the cost of owning the car.
  8. #33
    NW suburban Chicago
    hiss by my window
    A vacuum gauge can be used to check for restricted exhaust
  1. 93' 318is hesitation/ rough idle issues
    By gc8toe36 in forum 1991 - 1999 (E36)
    Last Post: 06-08-2012, 02:53 AM
  2. Cold start hesitation rough idle stalling
    By 82eye in forum 1975 - 1983 (E21)
    Last Post: 11-28-2007, 03:35 PM
  3. 1993 325is code 1283 and hesitation/rough idle
    By gt90 in forum 1991 - 1999 (E36)
    Last Post: 03-30-2006, 10:08 AM
  4. Replies: 9
    Last Post: 10-16-2004, 04:43 PM
  5. Hesitation during idle, what could be the problem
    By lancerr in forum 1991 - 1999 (E36)
    Last Post: 06-30-2002, 10:45 AM
