Page 3 of 5 FirstFirst 12345 LastLast
Results 51 to 75 of 115
Thread: TTFS Dcan cable does not work. 540i e39 SC.
  1. #51
    DeWitt, Michigan
    '97 540i/6, '97 328i
    Quote Originally Posted by Zep View Post
    For what ever reason Frank has had trouble getting fuel in after 6100rpm on these TU motors, the non-VANOS motors dont seem to be a problem though.
    I might be remembering this wrong, but it seems to me that Philly has been leaning out in the higher RPMs also, but not nearly to this extent. Plus, he's making significantly more boost. AND, he's injecting some methanol also, so without that he'd be even leaner.
  2. #52
    Mar 2012
    Lansdale, Pa
    98 540 6, SC'ed, 16psi
    I'm totally confused. Wth is no load?
  3. #53
    Feb 2016
    Ashgabat
    e36 v8 Turbo HX-40
    Quote Originally Posted by philly98540 View Post
    Fill, i meant when my car is staying and i push the gas pedal i have 10 psi boost on gauge 6500rpm. When i am on any gear 6500rpm giving me 3psi. What is wrong with my system? Can you please advise?
    e39 540i 6speed Supercharged,
    E36 v8 m62 with m60 headers, Turbp HX-40 0.6-0.5bar or 9psi, custom exhaust & Turbo manifold, injectors 440cc, ECU Invent EMS-2, Mishimoto Intercooler and oilcooler, etc…
  4. #54
    May 2015
    NZLD
    bmw
    Do some 4th gear pulls and log as much as you can. does you boost gauge have a data port? Try a cheap analog gauge and see what it says.
  5. #55
    Mar 2012
    Lansdale, Pa
    Mine is not lean up top.
  6. #56
    geargrinder's Avatar
    Mar 2010
    AndoverRockport MA & Intl
    E46M3Cic E39.540iT E84X1
    Confused about the screenshots of gauge.
    It appears in both cases the actual needle for the boost gauge shows the same thing - something like -.18bar, aka a little vaccum in both cases. Not sure what the digital readout at the bottom is?
    How is your diverter / bypass valve plumbed? Wondering if you have something funny there. If you can post pictures of your setup that might be easier to understand.
    2003 M3CicM6 TiAg
    Former:
    1985 MB Euro graymarket 300SL
  7. #57
    Feb 2016
    Ashgabat
    e36 v8 Turbo HX-40
    Why you are not paying attention on marked digits? That js real pressure. Needle is not working.
    Changed diverter. Same. Pictures will be attached.
    One more time. When i am on neutral position of my gear 6500rpm gives me 0.65bar or 10psi. When i am on any gear 1. 2. 3. 4. 5. 6 at 6500rpm my boost gauge shows me 0.2bar or 3 psi.
  8. #58
    Mar 2010
    Yesh you've said that. But the needle on the boost gauge shows something different than the numbers at the bottom. The needle does not show either 3 or 10 psi. How does that gauge work anyway?
    2003 M3CicM6 TiAg
    Former:
  9. #59
    DeWitt, Michigan
    I noticed something looked funky between those gauges, but I couldn't tell what was going on there either.. This is why I'm not a tuner for hire!
  10. #60
    Feb 2016
    Ashgabat
    e36 v8 Turbo HX-40
    Bro, boost gauge body has deformation due to high temperature of our weather. Direct sun made it melt. Digital part is working very well and corect.
  11. #61
    Feb 2016
    Ashgabat
    e36 v8 Turbo HX-40
    Gents, can you please check on you Supercharged engines your boost pressure on any gear when engine 6000rpm.
    I checked everywhere but did not find any leak in system. Still cannot understand why boost gauge shows 10psi pressure when i am full load engine up to 6500rpm and shows 3psi when i am on any gear (123456) at 6500rpm. Do you have the same?
    My opinion is when i shift any gear and load the engine my engine starts to increase consumption of air and due to that SC cannot supply air saffitient. Is that right? Al SC owners has the same?
  12. #62
    Mar 2010
    Quote Originally Posted by dovlet View Post
    Errrghz. Confuzin. Full load? Don't you mean:
    no-load (neutral) 6500rpm = 10psi
    and
    full-load (any gear, WOT on-road) 6500rpm = 3psi
    I thought that's what you've been saying.
    If your bypass valve was rigged wrong maybe you could see symptoms like that. Like if it was given pre-throttle plate instead of manifold vacuum it would not bypass at no-load, it'd build full boost at no load (i.e. bad). It should still build boost under load in that case but at least it would explain one half of the equation.
    I want to know exactly:
    - How your bypass valve is rigged.
    - How your boost gauge is rigged.
    That's why i asked for pix.
    2003 M3CicM6 TiAg
    Former:
  13. #63
    Feb 2016
    Ashgabat
    e36 v8 Turbo HX-40
    and
    Exactly
    This is my diverter valve
  14. #64
    Feb 2016
    Ashgabat
    e36 v8 Turbo HX-40
    Attachment 602212
    Above is my diverter
  15. #65
    Feb 2016
    Ashgabat
    e36 v8 Turbo HX-40
    Read logs and sent to Frank. My boost gauge has no data port. Tried chip analog pressure gauge. Same.
  16. #66
    Feb 2016
    Ashgabat
    e36 v8 Turbo HX-40
    Ok. May be below will give you some idea.
    Today i removed diverter by pass valve and put HKS blow off valve. Works greate and sound is nice to hear pish pish pish.....
    Started full load on 1st gear. Gauge read Max 3psi. 2nd gear full load 3psi. 4 has the similar results on top end.
    Then decided give load easy step by step. 2000rpm 4000rpm 6000rpm and pressure was 10psi. 3rd gear and started to increase rpm slowly step by step. Again 10psi at the redline. Then droped rpms to 4000 and noted about 6psi, then quick full load and again same picture. 3-4psi. LOOKS LIKE BELT IS NOT HOLDING....
  17. #67
    Mar 2012
    Lansdale, Pa
    Sounds like Boost Gauge tapped into charge pipe. Should be to manifold.
  18. #68
    Feb 2016
    Ashgabat
    e36 v8 Turbo HX-40
    My boos gauge is place on pipe between SC and engine as marked on picture below.
    You meant it should be installed after throtle body?
  19. #69
    Feb 2016
    Ashgabat
    e36 v8 Turbo HX-40
    Ok, looks like my belt is slipping. Removed my SC and going to machine shop to instal new thread to pickup little bit my tensioner. Lets see what will happen. If then still belt will be slipping will be constract something like Phile made.
    512201714354.jpg20170612_142652_resized.jpg20170612_142805_resized.jpg20170612_142632_resized.jpg20170612_142658_resized.jpg
  20. #70
    Mar 2012
    Lansdale, Pa
    Yeah, wrong spot for boost gauge. Must be after throttle body. Most connect to rear of manifold.
  21. #71
    Mar 2010
    Yes. I thought that might be the case. Boost gauge is totally wrong.
    The diverter valve pictures are not posting - again please post that. I Suspect similar mistake in plumbing type issue there.
    Do NOT run a blow off valve. Makes your car sounds like a douche , but more importantly the tune is a MAF based tune / ECU and a blow off valve totally screws the MAF readings and makes Franks attempts to tweak pointless. BPV will work FINE if connected properly. Douche nuggets that slam BOV's on cuz they cant figure out some other problem are generally doomed to a life of misery and poorly build malfunctioning everything. Its kinda like "i have a health problem and feel terrible but ill just take some cocaine cuz it makes me feel better!" Not solving the problem. Not good for things in the long term.
    2003 M3CicM6 TiAg
    Former:
  22. #72
    Feb 2016
    Ashgabat
    e36 v8 Turbo HX-40
    Her you are. So, today i made tentioner tighter and have 0.45bar which means about 6psi. Better than befor and looks like i had slipping my belt. Today am going to drive and test. Lets see if there is improvments.
  23. #73
    Feb 2016
    Ashgabat
    e36 v8 Turbo HX-40
    Gents, does some of you have testo logs for m62b44 SC Frank tune runing? I want just compare air consumption vs rpm. Also, mine is too lean afer 6000rpm. Something between 15-17 above 6000rpm.
  24. #74
    DeWitt, Michigan
    I just want to repeat because I'm not sure you understand the gravity of the situation, those AFRs in boost are asking for an engine failure. And I'm not a guy who's always worrying about an engine, because I know they can often withstand a lot of abuse... But that is really asking for it!
  25. #75
    Mar 2012
    Lansdale, Pa
    Some logs in one of my threads, but those are before my final pulley and injector I'm running now. Also my car is different ECU, pre vanos. Mcniblts was only one iirc that was similar to yours, but hes not around much anymore.
    As Tp said, do not run your car at wot with AFR over 12.5.
    If your on 42's, there should be plenty of fuel available if upper bins in tune are set correctly and fuel pressure is good. Mcniblts never upped his redline that high iirc, so I'm not sure anyone with your set up ever got a full tune from Frank with that redline. I may be wrong though.
  1. Replies: 0
    Last Post: 04-11-2016, 10:49 AM
  2. E39 540i vanos does not work.
    By dovlet in forum 1996 - 2003 (E39)
    Last Post: 03-17-2016, 03:12 AM
  3. Had to jumpstart my 540i now BC does not work!
    By pupqy in forum 1988 - 1996 (E34)
    Last Post: 07-11-2008, 04:26 PM
  4. Had to jumpstart my 540i now BC does not work!
    By pupqy in forum 1996 - 2003 (E39)
    Last Post: 07-10-2008, 10:20 PM
  5. 2001 540i park assist does not work
    By brewmastr in forum 1996 - 2003 (E39)
    Last Post: 07-09-2007, 11:35 PM
