Results 1 to 25 of 27
Thread: 02 530i hazards and interior lights coming on during startup
    Mar 2014
    United States
    02 530i
    Okay so for the past year every now and then when I start my car the hazards come on and also the interior lights, and I have to turn them off manually. Sometimes when I turn the car off the interior lights also stay on, so I went ahead and replaced my light control module hoping that would fix the issue but it didn't.i searched around the forums but I have not found a fix. Anyone have any suggestions?
    Jan 2016
    Ca
    2001 525it
    Ignition switch
    Aug 2016
    Virginia,USA
    528i, 525iT, M5
    +1
    Current Garage Highlights
    2003 525iT TiSilver
    2002 M5 TiSilver
    Former Garage Highlights
    2005 X5 4.8is
    2004 325iTs (2x)
    1973 Pantera L
    1969 Road Runner 383
    Mar 2014
    United States
    02 530i
    Quote Originally Posted by jclausen View Post
    Ignition switch
    I don't have any other symptoms (visor doesn't cause anything when running)
    Mar 2014
    United States
    02 530i
    Went ahead and replaced the ignition switch, wasn't the problem. Next?
    San Jose, CA
    1997 BMW 540i 6 speed
    What is the battery voltage before startup?
    Mar 2014
    United States
    02 530i
    Quote Originally Posted by edjack View Post
    13.2, the battery was recently replaced as well as the alternator.
    Mar 2014
    United States
    02 530i
    Bump
    Dec 2016
    Springfield, VA
    2001 750iL DD74441
    Have you spilled anything on your center console? It could be gunk in the hazard switch.
    How about your door looms? Any cracks in the conduit in any of the doors? Trunk loom?
    Mar 2014
    United States
    02 530i
    No, everything is good as far as I have found with the wiring, and I have replaced everything but the air bag/crash sensor unit in the center console but don't think it would be that?
    Mar 2014
    United States
    02 530i
    I may have found the culprit last night, I was able to get ahold of a laptop with p.a. Soft and found I had a code for the crash sensor being activated, I went ahead and cleared the code and so far it hasn't came back. I will update if the issue comes back for anyone experiencing similar issues.
    Mar 2014
    United States
    02 530i
    So after a few days it is doing it again, however now the interior lights aren't staying on so it's just the hazards...
    geargrinder's Avatar
    Mar 2010
    AndoverRockport MA & Intl
    E46M3Cic E39.540iT E84X1
    Hmmm.
    Does your theft system work? I think those systems go on when theft detection is triggered... if your car had the siren disconnected, it could be going into theft mode and you wouldn't know except for stuff like this. Although your symptoms seem a bit wider and random for that...
    Unfortunate news for you - it's actually the GM that controls interior lights, not the LCM. So if its module related it would be that. You could have a bad door sensor leaving the interior lights on for sure. The GM also controls the "DWA" (aka theft alarm) BTW. The hazards are more of a mystery, which is why the DWA theory is a possibility. When an alarm is triggered, the GM tells the LCM to flash the exterior signal lights. I had weird alarm problems when I had the "P-bus" shorted out in my car - basically the alarm system couldn't disarm and so would go off when you opened the doors etc. and wouldn't go off until you started the car. I could see some PO wrestling w/ that and deleting the alarm siren...
    2003 M3CicM6 TiAg
    Former:
    1985 MB Euro graymarket 300SL
    JimLev's Avatar
    Sundance Mesa, NM
    00 540/6, '16 Highlander
    Was your red clown nose light below the rear view mirror flashing too?
    It's suppose to flash if a break in was attempted. Like GG asked if the siren was disconnected/dead maybe you have a bad door sensor or bad interior motion sensor which is triggering it.
    Can you park the car and not lock it to see if the hazzards still flash?
    Mar 2014
    United States
    02 530i
    Ah good to know GG and Jim, I'll look into the gm module this week. The alarm works, however my passenger door lock is jammed or something because it doesn't lock with the central locking and I don't think I've ever noticed the clown nose flashing other than when it's armed. It may still be something to do with the crash sensor, is that supposed to be replaced after an accident? I rear ended a car that rear ended a car back in october and have just finished replacing everything. Looks like I'll start making a checklist of things to go through. I need to buy a new laptop so I can run p.a. Soft and scan/program all the modules again
    Mar 2010
    Yes, I've heard weird things about the crash sensor causing issues after being triggered. And yes for sure could also be related to the door lock issues tripping something. Of course the doors are all controlled by the GM so if the GM is problematic then that could be just another symptom rather than a cause (although the GM's are not known for high failure rate...) Good tip from Jim on the clown nose, I forgot about that.
    2003 M3CicM6 TiAg
    Former:
    Mar 2014
    United States
    02 530i
    Yea the clown nose doesn't flash when I get in the car or anything, only when it's locked
    Mar 2010
    Then might indeed be a confused / borked GM, or, the crash sensors / MRS system.
    If you could source or borrow a spare GM cheap that might be helpful to quick swap in.
    Again, there's a few stories of weird stuff like this from those airbag/crash bits going bad. There should be both the main center module ("MRS" module - you can replace those w/ junkyard ones as long as they aren't 'crashed' and are good... BTDT... but be careful w/ coding, they can get borked from improper coding attempts, BTDT too), and the side-impact crash sensors (which are in the floors under carpet apparently - I've never messed w/ one...) not sure which one you got the code for...
    2003 M3CicM6 TiAg
    Former:
    JimLev's Avatar
    Sundance Mesa, NM
    Never had any dealings with crash sensor problems. If the sensor was triggered the air bags and seat belt tensioners should have been triggered, right?
    Those events didn't happen.
    Mar 2014
    United States
    02 530i
    I'm still having this issue, however, it is less frequent than it was before. any more ideas on what it could be?
    Oregon
    '99 528i/5, '01 Boobaru
    Quote Originally Posted by syphilouis View Post
    If it hasn't been mentioned already .... xenon ballasts. Do you have xenon lights, and if yes, have the ballasts been replaced with anything aftermarket?
    I mention this only because those were exactly the symptoms my car was having after installing some cheapo ballasts ....
    Aug 2017
    Tampa Bay Area florida
    1998 528i
    So have you tried pulling the alarm fuse just to fill out that as a possible culprit?
    1998 BMW 528i My First Build
    (northeast) Indiana
    15 650ix GC & 14 X5 50i
    It's suppose to flash if a break in was attempted. ...
    ... The alarm works, however my passenger door lock is jammed or something because it doesn't lock with the central locking and I don't think I've ever noticed the clown nose flashing other than when it's armed. ...
    ...It may still be something to do with the crash sensor, is that supposed to be replaced after an accident? I rear ended a car that rear ended a car back in october and have just finished replacing everything.
    The clown nose (DWA status LED) illuminates when the car is armed...but also FLASHES in specific ways which can indicate an issue with open monitors. Does it flash rapidly for the 1st 10 seconds then slow down? If yes...perhaps you have a failing door module. See chart below to determine the status of your DWA (anti-theft alarm siren system):
    And since you indicated that you were in an accident...you may want to check further into the issue being your crash signaling. This feature was once contained into its own module...but since 9/96 build date-up...this feature was incorporated into the MRS/SRS (multiple restraint system/supplemental restraint system & GM programming). It turns on the interior lights and hazard lights (just like what you're describing) when involved in an accident...as well as unlocks the doors.
    Mar 2014
    United States
    02 530i
    Quote Originally Posted by pleiades View Post
    I have some issues every now and then with one headlight not coming on right away now that you mention it< this set of ballasts is only a year old though cause the ones that were on the car when I bought it started melting right at the bulb connector and caught fire. ill see if I can get another set and maybe that will solve this, however why would the interior lights stay on until turned off manually?
    Quote Originally Posted by Qsilver7 View Post
    where are the front crash sensors located?
    (northeast) Indiana
    Since your car was built after Sept/1996...you don't have "crash sensors" like BMWs had prior to 9/96. Your MRS/SRS system's collision & impact sensor info can be found in this TIS doc: https://www.newtis.info/tisv2/a/en/e...irbag-sensors/
  1. 01 X5 Flashers and Interior light come on during start
    By onequik1 in forum 1999+ X5, X6 (E53, E70, E71, F15, F16, G05, G06)
    Last Post: 02-04-2015, 05:24 PM
  2. Hazard & Interior lights come on while driving
    By zeroburn1 in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 02-02-2011, 07:32 PM
  3. Replies: 24
    Last Post: 11-29-2009, 02:05 PM
  4. Main interior light comes on and off randomly....
    By BMWManiac in forum 1992 - 1999 M3 (E36)
    Last Post: 11-05-2008, 12:38 PM
  5. Lift doorhandle and interior lights come on
    By ecooney in forum 1992 - 1999 M3 (E36)
    Last Post: 03-21-2008, 01:15 AM
