I have a 1984 E28 that has developed a water leak that shows up in the passenger side front footwell when it rains. I have had the sunroof drains blown out and added a vapour barrier to the passenger side front door. The car has spent most of its life in a garage and this has just started in the last 6 months with the car sitting outside. There is no body misalignment and as far as I can tell no rust in the firewall/doors.
Any ideas on what might be causing it?
Thanks in advance
There is an illness on e28s causing rust on the front part of floor. Check your surfaces for upper ( i dont know, how you name that thing, which you can use to lift your car. )
