Plan b! ...
She's rollin'
Well I didn't expect that!
You will also need to check for a bent shifter carrier and other shifter parts. I also bought my Coupe off of copart with a hit harder than yours in the front. My transmission mounts were broken and I thought I had a bad transmission but it ended up being a bent shifter carrier and I was rubbing the driveshaft with shifting parts, especially in second. If everything is an inch and a half off, I guarantee the carrier is bent. Your transmission may be fine. Keep going. It's a fun build to watch.
1999 M Coupe Boston Green, Beige, H&R/Bilsteins, Underdrive Pulleys, Euro 6 speed, UUC SSK and Randy Forbes in the back
2002 2.5 Z3 roadster Oxford Green, auto, all stock
2013 Ram 3500 Crew Cab Dually 385 HP, 850 ft lbs torque at 1600 rpm, all stock and staying that way
2004 Mini Cooper Chili Red, daily driver, modified almost daily
Dexron 3 ATF is what the factory fill was in the manual transmissions so if that's what you put in, no need to change it unless you feel like it. I waste money and run Amsoil 5-30 MTF and absolutely love it. As far as a rear window, there are two options, OEM or the emiata window which is considerably cheaper and is what I put in my car and it has held up very well.
http://www.emiata.com/Z3Window.asp
I will still bet your linkage is bent. I could not tell until it came out that it was trashed. It should be straight in both plains.
Looking good, nice score on the hood!
