hello
98 740i
the shift lever locked up and i am unable to get it out of park
am i correct in assuming this has something to do with some sort of solenoid that activates when the brake pedal is depressed?
BTW dont hear any thumping from a solenoid when i depress the brake pedal.
where would such a mechanism be, down by the pedal or in the shift housing?
anyway its stuck, is there some sort of work around or reasonably straight forward fix?
thanks for the advice
pop the plastic trim aren't knob and see if you can figure it out, I never had such a problem so can't really tell what to look for, afaik brake pedal locks it if not pressed, ignition switch locks it if not (at least) in first position and button on the knob itself locks it too
Instagram.com/nordmanmg
Your current situation is not your final destination
It has often been known to be coins or other objects actually dropping down and jamming things ... as Nordman suggested , pop the trim and have a poke around before assuming the worst ... you may be lucky . I know other guys on the UK forum www.the7seriesregister.co.uk have had these issues before and solved them relatively easily from memory .
Here's some suggestions from a past thread where the same question was asked. I recommend PSJR's suggestion to quickly rule out the shift interlock solenoid (because I believe without electrical power...the shift solenoid is kinda "deactivated" and may allow you to move the gear shift lever):
i performed the tests indicated
yes- when the battery is disconnected the shifter can move.
so my next questions....
1)is this a basic DIY or more involved and where is the solenoid located?
2) is there a temporary bypass where i can manually move something within the shifter
housing to move the lever.
Note-after performing the tests indicated i banged on the shifter housing and something must have loosened up because i can now occasionally move the lever normally.
i am afraid of moving the vehicle for fear of getting stuck again.
this is why my second question is particularly relevant.
i browsed around the shifter housing but can not determine how i would go about disassembling the console.
Pull the shift boot up then you can pop the shift plate up pulling on the boot opening, all of this stuff is compression clip held so just pulling on it is the proper way to remove but you may break old plastic clips anyway, it happens. Then you can see the interlock lever and at least flip it manually when you need to shift out of park plus you can see what is the problem. If you need to go further and remove the wood console you are half way there. There will be a couple screws exposed under the shift plate. Couple more up by the armrest.
---- Processing Individual ----
Z1XX Upholstery
Seats front and back in Epingle / leather englishgruen,
As Schl.Nr. B9EG.
Front seat backrest in Montana Englishgruen (No. 8 174 861)
Other interior equipment as for Volleder Nappa englischgruen,
Schl.Nr. P5EG
...I sure there's a video on youtube...if not one for the e38...there should be one for the e39...and even though there's a slight difference...the overall design is similar.
Thanks I will investigate from your instruction
if the solinoid needs to be replaced is it within the housing also or under the dash near the brake?
Z1XX Upholstery
As Schl.Nr. B9EG.
Schl.Nr. P5EG
It's #7 in the diagram and link to part nbr index below (called the magnet):
It's #7 in the diagram and link to part nbr index below (called the magnet)...as mentioned in post #4 in AquilaBMW's quote:
