Who's tune do you have?
RK Tuning gives you this option when you buy his tuning package
"Backfire/Burble. This makes your car backfire or burble when you lift off the gas. The aggressiveness can be adjusted depending on what you want. We suggest catless downpipes if you want an aggressive burble / backfire. "
