Page 4 of 6 FirstFirst 123456 LastLast
Results 76 to 100 of 148
Thread: Ruskii's 2001 740iL
  1. #76
    Oct 2013
    Louisa, VA
    2007 Z4 M Coupe
    Quote Originally Posted by Zedbimmer View Post
    I ended up redoing my headliner due to houston heat. Its the glue that I used the first time. It would sag, I would pat it straight and after a day or two it would sag again.
    Yup! That's exactly what happened to me, even though I followed the glue directions. I did notice that the spot where headliner curves up closer to the roof (above rear passenger seats) is a lot hotter than more flat areas. I think this greatly contributes to the failure; a neat idea to give extra head room, but horrible design for longevity of the headliner.
    Took my car to get state inspection... it would not pass (luckily they didn't remove my current sticker!) due to front lower and rear upper control arm ball joints failure. My wife keeps telling me to buy a Toyota.
    Current: 2007 Z4 M Coupe (blue/black)
    Previous: 2001 740iL Sport (black/black), 2000 528i Sport (black/tan), 1995 318is (black/black), 1991 318is (white/black)
  2. #77
    Oct 2013
    Louisa, VA
    2007 Z4 M Coupe
    Got my parts in! Now I am just waiting for few tools to arrive either tomorrow or Wednesday. Need to stop by Advance Auto and rent the rear ball joint press.
    I hope the rear eccentric bolts didn't fuse - I should probably call my local stealership to see if they have them on hand... just in case
  3. #78
    Oct 2013
    Louisa, VA
    2007 Z4 M Coupe
    Help! Bolt is stuck!
    I hope someone could chime in and offer some advice on a stuck rear bolt of eternity, which holds the rear ball joint and integral link?
    Driver's side bolt came out with no issues, but the passenger side is stuck. I've used impact gun and BFH with no results. The bolt is trashed now, since it got banged on so hard... The bolt spins and the bottom tube of the integral link spins as well. I assume they got fused together somehow?
    Any advice is really appreciated!
  4. #79
    Oct 2013
    Louisa, VA
    2007 Z4 M Coupe
    By the way, I got everything replaced, aligned and even had all wheels rebalanced (had vibration at 60+mph). I'll upload some pictures later showing the carnage.
    I have to say, with Meyle HD thrust arms, there is more road feedback in the steering wheel = I can feel more bumps/imperfections, compared to the previous control arms. I have mixed feelings about this "upgrade."
  5. #80
    Rutland, Vermont
    E30 E38 E46 E85 F150 GTI
    Quote Originally Posted by Ruskii View Post
    How is it during braking? Any vibrations?
    2000 740i Sport | 2004 330xi | 1988 325i Vert | 2003 Z4 2.5 | 1995 Ford F150 | 2018 GTI
  6. #81
    Oct 2013
    Louisa, VA
    2007 Z4 M Coupe
    Nope
  7. #82
    Jan 2015
    Tempe, AZ
    1995 525i/5
    I agree with your observations on the Meyle HD thrust arms... I have them on my 540it which has more or less the same suspension setup as the 740il. I do feel way too much of the road through the steering wheel, especially when the road quality is poor. I plan to go back to Lemforders for that reason.
    1995 525i 5-speed - Thread
  8. #83
    Jul 2018
    Tallahassee, Florida
    1999 740i Sport
    I can't say I have never done that, but it was in a pinch as my wife and son were leaving town in my son's car and I couldn't get my hands on a regulator... but it was fixed properly upon their return...
  9. #84
    Oct 2013
    Louisa, VA
    2007 Z4 M Coupe
    Quote Originally Posted by dannyzabolotny View Post
    Darn. I was hoping that they would "break in" a little bit, like shocks and springs, and would not provide so much road feedback.
  10. #85
    Jan 2015
    Tempe, AZ
    1995 525i/5
    I kinda hoped for that too, but it's been a year and they still feel kinda bad. Granted, I'm also running 18's with fairly low-profile tires (245/40/18 front and 275/35/18 rear) so it's a pretty firm ride to begin with.
  11. #86
    Oct 2013
    Louisa, VA
    2007 Z4 M Coupe
    Pics!
    Finally got around at uploading the pics.
    Carnage:
    Totally fused together on the outer side of the integral link and ball joint:
    Oh and this will totally buff-out and be good as new...
  12. #87
    Oct 2013
    Louisa, VA
    2007 Z4 M Coupe
    The only way I was able to get the thrust arms disconnected from the knuckle was to take off caliper and rotor, and rotate the dust shield so the pickle fork could be hammer from outside of the car. 4-5 hearty "love" taps with BFH and it popped!
    And here is the comparison of Meyle HD bushing vs. unknown OE style bushing. Note how the old bushing looks slightly twisted = no preload!
  13. #88
    Jan 2015
    Tempe, AZ
    1995 525i/5
    I snapped a Harbor Freight ball joint separator one time, and then took it back to the store and demanded a replacement. Initially they refused but eventually they replaced it after I asked to speak with the manager.
  14. #89
    Rutland, Vermont
    That’s a lot of hard work right there. Great job! Don’t want to repeat that anytime soon.
  15. #90
    Oct 2013
    Louisa, VA
    2007 Z4 M Coupe
    Yeah at my local Advance Auto Parts, a guy behind the counter was iffy about it when I came to return it but the manager said it was not problem. Apparently, they just periodically contact the manufacturer of those tools and request replacement pieces (e.g. bent bolt).
    Quote Originally Posted by clarkitect View Post
    Thank you!
  16. #91
    Dec 2009
    Dallas,TX
    '98 E38 740IL, '01 740i
    Holy hell, is that common? I need to rebuild my rear end and that worries the hell out of me.
    Sent from my SM-N950U using Tapatalk
    TRPCHGE - '01 740i Black/Black 230k'ish - Power folding mirrors, Mk.IV Nav, 16:9, M-pars, Sport seats, Sport wheel, Steptronic, Euro rear fog switch, 2.50" X-Pipe, Shadowline, E53 4.6is Cluster, Lacewood interior, Chromeline, 3.15, Bilstein B6+H&R Stage II's. - SOLD 06/21
    BSKCASE - '98 740il Arctic Silver/Black 175k'ish - Face-lifted, 3" Projectors, Shadowline, 01 Tails, Hydro Trunk, Sunshades, 750il Full interior retrofit, Sport Seats, Steptronic, Face-lift Steering Column, X5 Steering wheel, E53 4.6is Cluster, Euro E66 Piano black/Chrome Grab-handles, Chromeline, Suede Pillars/Headliner, Auto wipers/Lights, Lighted Handles interior/Exterior, Dual battery retrofit.
    WIP: Custom Style 42 18x9.5" ET12, 18x10.5" ET8, 3.15 LSD Rear diff.
  17. #92
    Oct 2013
    Louisa, VA
    2007 Z4 M Coupe
    When I did this on my e39, I did not have this issue. And all videos online and DIY threads don't mentioned seized up eccentric bolt that goes through the ball joint. That bolt is huge! Thick as your finger and about 1 foot long.
  18. #93
    Oct 2013
    Louisa, VA
    2007 Z4 M Coupe
    So after changing all of the control arms I am still getting a random "thud" (and could feel it with my left foot on the footrest) on the front driver's side. I thought this "thud" was due to bad thrust arm bushings, but now I have a hunch it's the driver's side motor mount.
  19. #94
    Dec 2013
    San Antonio
    850,76 2002 &530,84 633
    I was told to use some high-heat spray adhesive to hold headliner in place, otherwise, the summer sun and heat with cause cheaper glues to loose their adhesion. I already bought this #M Headliner glue so I guess I will try it out.
  20. #95
    Oct 2013
    Louisa, VA
    2007 Z4 M Coupe
    Changed oil and both engine mounts. Driver's side mount was shot! Let's see if new mounts make any difference...
    And while I was under the hood, I also decided to check and top up my coolant. Apparently my radiator cap is slowly disintegrating. It's missing one of the three o-rings and found second o-ring in the expansion tank. Time for a new cap! Given that I have a lower temp tstat, I am thinking of going with 1.4 bar cap.
  21. #96
    Rutland, Vermont
    Have you change the trans mounts too? If not they are shawt!
  22. #97
    Oct 2013
    Louisa, VA
    2007 Z4 M Coupe
    No... dang it, more parts replace.
  23. #98
    Oct 2013
    Louisa, VA
    2007 Z4 M Coupe
    Last night was coming home and got the dreaded transmission failsafe error message, but the car drove fine. With recent threads about transmission problems my heart skipped a bit for a moment with a thought of "oh no, am I next to have issues?"
    Checked codes via INPA and got the following errors:
    1) Transmission = 151 CAN brake signal
    2) Chassis = 116 Brake switch error
    3) Engine = 106 Switch brake
    Do they correlate with each other? What is this transmission error "151 CAN brake signal?"
  24. #99
    Feb 2010
    Hampshire UK
    99 840ci Sport Indv
    I think you have answered your own question - the brake switch has failed. The switch is fail-safe in that it contains two switches which should both switch at the same time - and if they don't it will bung up an error code. Time for a new one.....
    My BMW Repair YouTube Channel
  25. #100
    Oct 2013
    Louisa, VA
    2007 Z4 M Coupe
    Thank you for the confirmation, Timm!
  1. 2001 740iL - What Options?
    By jr87492 in forum 1995 - 2001 (E38)
    Last Post: 04-01-2004, 11:35 PM
  2. Pricing info - 2001 740iL
    Last Post: 03-29-2004, 04:09 PM
  3. 2001 740il, NJ, $36k
    By rgc1265 in forum BMW Cars For Sale / Wanted
    Last Post: 03-15-2004, 12:38 PM
  4. Best price anyone has seen for a 2001 740il sport?
    By AlexeTDog in forum 1995 - 2001 (E38)
    Last Post: 12-10-2003, 12:57 PM
  5. Is this a good price for a 2001 740il?
    By edcheung in forum 1995 - 2001 (E38)
    Last Post: 04-06-2003, 05:56 PM
