Page 6 of 6 FirstFirst 123456
Results 126 to 148 of 148
Thread: Ruskii's 2001 740iL
  1. #126
    Oct 2013
    Louisa, VA
    2007 Z4 M Coupe
    I asked them to check for anything loose and was told everything was good and tight. Maybe the alignment dude didn't tighten the bolt on the tie rod tight enough, so the threads backed out a little bit.
    Current: 2007 Z4 M Coupe (blue/black)
    Previous: 2001 740iL Sport (black/black), 2000 528i Sport (black/tan), 1995 318is (black/black), 1991 318is (white/black)
  2. #127
    Oct 2013
    Louisa, VA
    2007 Z4 M Coupe
    Well boys and girls, I finally pulled the trigger on some BC Racing coilovers: Extreme low version with the Swift springs upgrade (kept the suggested 9k/6k spring rates).
    Hopefully later this Spring I will swapping them in!
  3. #128
    Dec 2013
    San Antonio
    850,76 2002 &530,84 633
    Quote Originally Posted by Ruskii View Post
    I have an E31 and converted over to modified coilover struts from Ground Control with threaded perches on back of car. I am very happy with the results and looking forward to driving my car again after pulling rear suspension out for a rebuild. I am running 450/550 lb springs which is fine for everyday driving and car also felt pretty good on the track, but with a little too much body roll. I have the rear suspension out right now for a rebuild and i modified subframe slightly to accommodate a larger sway bar and then I will install the larger bar on front so I should see a big improvement with reduced body roll. The E31 requires a stiffer rear spring since they are inboard and not a true coilover. Right has been lowered apprx 1.5". I also have a 3.91 LSD to install at the same time. I hope to complete rebuild in the next couple of weeks. I am missing the SCCA TNIA event today, darn it!
  4. #129
    Oct 2013
    Louisa, VA
    2007 Z4 M Coupe
    I love your garage JDP530! I wish I had at least one of them (a 2002 in a roundie style though )
  5. #130
    Oct 2013
    Louisa, VA
    2007 Z4 M Coupe
    Just got a text message from my wife, "What is this large and heavy box that says it's for BMW. And how much did you spend!?"
    My coilovers are here!! (that was quick)
  6. #131
    Oct 2013
    Louisa, VA
    2007 Z4 M Coupe
    Finally opened the box
    Front springs are 5.5" and rears are 9" tall (extreme low version). Curious to see how they will feel...
    I am planning to install them during the week of April 15th. Still tossing ideas in my head about going with a square set of style 95s or 231s.
  7. #132
    Dec 2013
    San Antonio
    Cool! What spring rates are you using? I wonder how a staggered set of wheels would look?
  8. #133
    Oct 2013
    Louisa, VA
    2007 Z4 M Coupe
    Standard: Front 9k, rear 6k.
  9. #134
    Oct 2013
    Louisa, VA
    2007 Z4 M Coupe
    I finally caved in and got akebono front brake pads, as I am just so sick of nasty brake dust the current pads produce. And while I am there, might as well change the oil.
    Today, I've replaced the rear shocks and hopefully tomorrow I'll do the fronts.
    The rear shock mounts and bump stops are completely destroyed, but the shocks themselves may still be fine and EDC worked!
  10. #135
    Rutland, Vermont
    E30 E38 E46 E85 F150 GTI
    A solid day’s work right there. Looking forward to seeing the new stance!
    2000 740i Sport | 2004 330xi | 1988 325i Vert | 2003 Z4 2.5 | 1995 Ford F150 | 2018 GTI
  11. #136
    Oct 2013
    Louisa, VA
    2007 Z4 M Coupe
    Long overdue pictures (excuse the dirty car). Also, some numbers for curious minds (measurements from fender arch to floor):
    Front:
    • Before = 28 1/2"
    • After = 26"
    • Total drop = 2 1/2"
    Rear:
    • Before = 27 3/4"
    • After = 25 3/4"
    • Total drop = 2" (had to raise the coils 10mm from the factory preset)
    Currently damper settings:
    • Front = full soft
    • Rear = 10 click from soft
    Before shots for comparison (front wheel gap is insane!):
    After shots:
    With coilovers fitted, I can now say that ALL of the suspension parts have been replaced. Also had to replace front left brake caliper, since the piston wouldn't collapse all the way to fit new pads.
  12. #137
    Rutland, Vermont
    That looks awesome! Some spacers would kick it up another notch I think, but really looks much better than the high rider OEM look. Nice work!
  13. #138
    Oct 2013
    Louisa, VA
    2007 Z4 M Coupe
    Thank you! I really like the way it sits so far. I may get a square set of style 95 or 231 and then add spacers.
    Also, what should I do with my EDC shocks? I am hesitant to throw them away since they worked and EDC functioned properly...
  14. #139
    Oct 2013
    Louisa, VA
    2007 Z4 M Coupe
    Squeaky rear coilovers - Fixed!
    Fixed my squeaky rear coilovers today -- hopefully the solution will last for a while, otherwise I may have to explore other options.
    Symptoms:
    • High pitch squeaky noise from the rear, while going under 30mph on minor imperfections in the road
    • Noise is only heard outside of the car
    • Noise appeared/noted several weeks ago (while driving with the windows down)
    • I was able to replicate the noise while pushing up and down on each quarter panel by the tail lights
    Culprit:
    • I highly suspect the rear springs, specifically bottom section where the coils touch each other
    • On both springs, there is a tiny spot of rust, where I believe the coils rub each other = rubbed off the paint and caused rust/squeak (see pic below)
    Solution:
    • I have unscrewed all perches, cleaned everything up, and then sprayed silicone lubricant on mating surfaces of each perch, strut mount, and spring where tiny bit of rust was noted
    • Reset 2mm preload and tightened everything back
    Test drive resulted in no more squeaking!! If the squeak comes back, I may try putting a tiny bit of rubber in that spot and see if the issue goes away, but for now... beer time!
  15. #140
    Dec 2013
    San Antonio
    I had a darn squeaky noise from the back of my car but I had installed some thin 1/8" rubber pads for spring seats. I thought the swaybar links or bushing might have been squeaking but it wasn't until i removed the rubber pads that I got rid of noise.
  16. #141
    Oct 2013
    Louisa, VA
    2007 Z4 M Coupe
    Quote Originally Posted by JDP530 View Post
    Interesting. These coilovers come with plastic spring pads, which I've also lubricated with silicone grease. Fingers crossed, the rear will stay squeak-free, so I can tackle other issues on this car.
  17. #142
    Oct 2013
    Louisa, VA
    2007 Z4 M Coupe
    Went to a pick-and-pull yard, mainly to find an instrument cluster and auxiliary water pump... but while there, grabbed few extra goodies.
    1) '04 or '05 instrument cluster from e53 with software version 23. My cluster is on a fritz!
    2) Auxiliary water pump. My current pump is leaking through the weeping hole.
    3) Trunk lid grab handle. My handle broke into many pieces a week ago, while closing the trunk.
    4) A pair of black e53 sun visors. I painted my original ones, but OE fabric is much better.
    5) e53 shift knob. My all-wood knob has a million cracks.
    6) A pair of headlight gaskets, where they seal against the hood. My gaskets completely disintegrated, and I was left only with a plastic frame.
    7) Engine bay gasket near the fuse box. For some reason, my gasket was pinched and deformed, which may have allowed water into the fuse box (I had an issues with the car after automated car wash).
    8) Passenger side mirror glass. I still need to find the correct replacement, as my car came with the self-dimming glass; the replacement is a standard glass.
    9) A pair of kidney grilles that I will paint black, so I can try the "blacked out" grilles. These are OE, so they should fit better than knock offs.
    10) Grabbed a pair bulbs to make quad brake lights, but then found a pair of aftermarket LED "celis" style tail lights. Not a big fan of LEDs, but my current lights are really sun faded and cracked (water gets in between actual layers of plastic). I may re-seal, paint in red, and then polish them.
    Lewt!
  18. #143
    Jul 2012
    California Inland Empire
    2001 740iL /1991 E32
    Lewt!
    Looks like you had a good day.
    2001 740iL Guides,chains,vanos done. Full steptronic retrofit,3:15 diff. DUDMD tune. Sport seat retrofit. Porn lights
    [IMG][/IMG]
    Nitto ZR 285/40/18 rear 245/45/18 fr. UUC springs front. Porn lights. Sport wheel
    1991 735iL UUC springs front only Style 42 wheels
  19. #144
    Oct 2013
    Louisa, VA
    2007 Z4 M Coupe
    Hi boys and girls!
    I haven't been around for a while... well, life has been a complete mess for me for the last half of 2019. May 2020 bring more joy!
    Anyways, after over 3 years of floppy passenger rear seat pocket, it's finally fixed. First, used super glue to piece together this "mosaic," then reinforced the hinges with some metal, and finally epoxied the heck out of it (no pics, but I did not hold back on that tube of epoxy)! No more floppiness.
    Also fixed passenger lower B-pillar trim, as the bottom two tabs were broken.
  20. #145
    Lexington, KY
    09 X5 & 01 740i Sport
    Nice work! I cheated and ordered a used pair (in nice condition) off of ebay and just replace mine. I might try to refurb mine and pay it forward if I have the time.
  21. #146
    Dec 2009
    Dallas,TX
    '98 E38 740IL, '01 740i
    Hi boys and girls!
    Amazing work, I bought a set of 750 seat backs and one of them is super floppy so I'll probably be doing exactly this.
    Fantastic write up.
    Sent from my SM-N975U using Tapatalk
    TRPCHGE - '01 740i Black/Black 230k'ish - Power folding mirrors, Mk.IV Nav, 16:9, M-pars, Sport seats, Sport wheel, Steptronic, Euro rear fog switch, 2.50" X-Pipe, Shadowline, E53 4.6is Cluster, Lacewood interior, Chromeline, 3.15, Bilstein B6+H&R Stage II's. - SOLD 06/21
    BSKCASE - '98 740il Arctic Silver/Black 175k'ish - Face-lifted, 3" Projectors, Shadowline, 01 Tails, Hydro Trunk, Sunshades, 750il Full interior retrofit, Sport Seats, Steptronic, Face-lift Steering Column, X5 Steering wheel, E53 4.6is Cluster, Euro E66 Piano black/Chrome Grab-handles, Chromeline, Suede Pillars/Headliner, Auto wipers/Lights, Lighted Handles interior/Exterior, Dual battery retrofit.
    WIP: Custom Style 42 18x9.5" ET12, 18x10.5" ET8, 3.15 LSD Rear diff.
  22. #147
    Oct 2013
    Louisa, VA
    2007 Z4 M Coupe
    Quote Originally Posted by Sabreslight View Post
    Fantastic write up.
    Get 'er done!
  23. #148
    Oct 2013
    Louisa, VA
    2007 Z4 M Coupe
    Rode my bike to meet Alpine 7even and his fleet of 7s this past weekend! Super cool guy and drool-worthy cars!!! Next time I need to bring my e38.
  1. 2001 740iL - What Options?
    By jr87492 in forum 1995 - 2001 (E38)
    Last Post: 04-01-2004, 11:35 PM
  2. Pricing info - 2001 740iL
    Last Post: 03-29-2004, 04:09 PM
  3. 2001 740il, NJ, $36k
    By rgc1265 in forum BMW Cars For Sale / Wanted
    Last Post: 03-15-2004, 12:38 PM
  4. Best price anyone has seen for a 2001 740il sport?
    By AlexeTDog in forum 1995 - 2001 (E38)
    Last Post: 12-10-2003, 12:57 PM
  5. Is this a good price for a 2001 740il?
    By edcheung in forum 1995 - 2001 (E38)
    Last Post: 04-06-2003, 05:56 PM
