Hey all,
So I'm trying to get NCS Dummy set-up on my laptop so I can do some coding to my E36 and I'm not sure what interface and cables to use.
My car is a 1998 with the 20 pin under the hood.
Is it safe to assume that I need a 20 pin -> OBD interface (I have this one: http://www.ebay.com/itm/371111270754 ) and an OBD -> USB cable to connect to my laptop?
Did I purchase the wrong interface because it's OBDII and not OBD?
Can I use an OBDII -> USB cable or does it have to be specifically OBD -> USB?
Thanks for the help!
I also forgot to mention that I have one of these INPA K+DCAN cables that I used with my E92M:
I have no idea if this can be used with OBD or not...
What modules are you trying to code on your 98 M3?
Many modules you can code via that K+DCAN posted (plus 20-pin adapter linked earlier), but not ABS/ASC+T and KOMBI. The latter 2 need something called ADS interface on a true serial port (along with an older version of EDIABAS/INPA)
And don't get hung up on OBD2 or OBD. They're all OBD2 if it has that connector.
-Abel
- 2000 Z3: Many Mods.
- 1999 S52 Estoril M Coupe
- 2016 Mini Cooper S
Hey, thank you for posting. I really appreciate it.
So, I'm trying to clear out the SRS airbag error code (I recently swapped steering wheels and now have an error) and see if it goes away for good or if I have a real problem
and
I'm getting ready to remove the seats from the car and install a race seat. I'm concerned it will throw a seat belt error and wanted to know how to code that out (as needed).
I'm also reading about using NCS Dummy to remove the deadzone in the coolant gauge, which sounds awesome. My car is used on the track in 100*F weather, so having a more accurate gauge would be VERY useful for me.
For the coolant gauge you need more advanced interface, either ADS or ICOM, because the instrument cluster is only on L-line. It's a nice enough thing to do, a drop of 10 degrees F from the buffer will be just right. It will start moving the needle past midline as the temp is just getting a little hotter than usual.
I did
31,92,B0,CE,E7 (middle area is 176-206 deg F)
instead of stock
31,92,B0,D8,E7 (middle area is 176-216 deg F)
Any more than that and the needle will climb too early, and I didn't like it on a street car. A bit of buffer is a good thing.
The airbag module you can code with your INPA K+DCAN OBD cable and a 20-pin adapter, connected under the hood.
-Abel
golgo13: Keep in mind that NCS Dummy is not a standalone coding tool. It's a helper tool to make working with NCS Expert much easier and achieve functionality that is not possible with a standard NCS Expert installation. So before even thinking about using NCS Dummy you first need a working NCS Expert setup.
L-line? I need to go back to BMW coding 101 since I have no idea what that means, but I'll go do some more googling. INPA was installed onto my machine by a merchant for remote coding with my E92M last year and I've only used it to read and clear error codes. I don't even know how to load up the E36 and connect. I was unable to make it work last time I tried but maybe I picked the wrong DME?
I have seen this ADS interface: http://openlabs.co/store/Tiny-ADS-In...-pin-connector which should work, so long as my laptop has a serial port. I have also seen ICOM hardware, but looked pretty pricy.
Cool. I guess I'll have to find an INPA FAQ for the E36
Very nice! I want to do this for sure! I wish there was a TLDR version for guys like me. I assume those are hex entries in memory? I'll have to come back to this once I know how to locate, back-up and edit my files with the proper editor.
Thanks! I'll be sure to try and find NCS Expert and use the Dummy as a wrapper. I sort of gathered that and the fact that NCS Export is not freeware, so I will be buying it as well.
Dont pay for NCS expert. Its safe to say that nobody has a genuine copy that should be saleable. Pretty sure BMW did not even sell the software in the first place. You may need an ADS interface to communicate with the airbag.
Current:
- 09 335i MSport, FBO.
- 98 Euro M3, Estoril Blue
- 04 M3, Carbon Black, 6 Speed Coupe
- 06 M5, Black on Black, Full Leather.
- 73 3.0CS, Tagia Green, 5 speed M30b35 converted
Ex's: 1984 325e, 1988 325IX, 1992 525I, 1995 540i/6, 2002 330i, 2005 330xi, 1992 850i, 2003 330i #1, 2003 330i #2, 2002 330ci, 2004 330ci, 2007 328CI, 2007 335i, 2001 M3, 2006 M5 6 speed
I think that interface I linked should work. I believe my laptop has a serial port, so I should be good.
Alright, thanks to 328 Power 04's help I'm all set-up. Tools work great and the step-by-step was perfect for me. I found that with kids, my time is so much more limited so I appreciate the on-ramp for getting up to speed.
Last night I tried to wing it and see if I could figure out how to code without RTFM for NCS Dummy, but alas I was unsuccessful.
I unpacked a KOMBI file, edited it and then repacked it... which is lol. I think I'll actually read about Trace Functions in NCS Dummy now...
Nice! You learned how to unpack and modify the kombi daten? I think it's .C27 version on your car?
I'm impressed.
Ya, the only way you will be able to code/write to the KOMBI is through ADS and true serial, and the older INPA pack with EDIABAS 6.4.7 or 6.4.3.
-Abel
Yeah, and I saw the hex values for the temp gauge in the data and made edits, even if they were not actually editing values for the KOMBI module.
What's the benefit of this? I can't understand why that would even be necessary.
Oh, that's too bad. I had forgotten that little detail about the ADS...
I'll have to see if I can track down an older EDIABAS as well.
There isn't anything in the NCS Dummy instructions that go over that.
So that won't work without an ADS cable and an older EDIABAS, huh?"There are several approaches on getting other data values coded into the module, like nettodata coding or disassembly (see later), but starting from NCS Dummy version 0.6.0.0 it is possible to add new parameters from within the graphical trace editor and update the NCS Expert DATEN files. To do so, right-click on a function or function parameter and choose "Add Parameter" from the popup menu. A new parameter is added to the function and you can enter a custom data value and (optional) keyword. By default NCS Dummy gives new parameters keyword "new_parameter" but you can enter anything you like - the keyword does not even have to exist in the keyword file. You can add as many parameters as you like and parameters may share the same data value, but all parameters must have unique names. Once satisfied with the new parameter(s), update the actual NCS Expert DATEN files by choosing "Update Module..." from the "Module Functions" button dropdown menu. If something is wrong with the entered data, for example an empty or duplicate keyword or data value outside the mask, NCS Dummy will highlight the faulty parameter and field(s) in red and prevent you from updating the module until the fault is corrected.
In the example below function "WL_DAUER" was expanded with six new parameters: "10_seconds" (0A), "20_seconds" (14), "30_seconds" (1E), "40_seconds" (28), "50_seconds" (32) and "60_seconds" (3C). Remember that data values are always hexadecimal!"
That's too bad. I guess I'll have to spend the $50 on that interface anyway. Well, I was able to clear my airbag error with INPA so that's a plus still.
This cable should suffice so long as my laptop has a serial port, correct?
Yes, that's the same ADS interface I have, well, mine's a little more barebones. I don't use mine anymore, as I have a couple of ICOMs, and no Serial port computers. (ICOM can connect to KOMBI with new INPA/EDIABAS versions just fine)
I already sent you the link to software, if you read that first page carefully, it has links for the older versions you'll need too.
Because the standard daten files are what write the temperatures to the KOMBI eeprom. The daten file you unpacked is more of a eeprom translation file... with preset temps only.
When you customize the preset daten files, it will write your custom data back in.
If you were to use an EEPROM reader on the cluster's eeprom, you'd be able to modify it yourself. But it requires more hardware disassembly and soldering.
-Abel
I got mine genuine from connections to a dealer that was about to throw away boxes and boxes of ICOM parts and broken ICOMS. There were mostly simple faults in the broken ones, so I mix and matched and made a few good ones... which some then went to the people supplying the connection. So I can't put a value on them, but it was just through knowing the right person. My 'cost' was the time for taking them apart and putting spare parts together to create (a few) good ones.
Non genuine Chinese ones are around $250-$300 (specifically look for A2 ICOM with a heat sink built in, the Chinese ones have heat issues). xcar360.com sells a good one. But they work on every BMW ever made with a diagnostics port.
-Abel
Cool.
$50 interface it is!
- requires a "real" serial port, as does every ADS interface in existence; will not work with USB-serial adapters
Looks like my laptop doesn't have a serial port.
Am I boned?
I also noticed the values for my car are actually
Not sure what to do with this info. I'll have to see where the E36M values are discussed.Code:TEMP_GEBERWERT_1 wert_01 - 31 TEMP_GEBERWERT_2 wert_01 - 7B wert_02- 92 TEMP_GEBERWERT_3 wert_01- B0 TEMP_GEBERWERT_4 wert_01 - E1 wert_02 - D8 TEMP_GEBERWERT_5 wert_01 - E7
Post the text contents of the daten file you decompiled so we can see. But Most likely it's .C27 (you won't know for sure until you connect to car)
-Abel
I'll do that.
In the interim, outside of ICOM is there a solution to my laptop lacking a serial port?
Not really any other solutions. Either find an old computer/laptop with a true serial port, or find a friend with one. Or someone with an ICOM with "C" adapter.
This is the line you should be looking for in the daten. Stock is set to kennlinie_02, so those values are what get applied to the KOMBI.
PARZUWEISUNG_FSW : {} 00000084 0005 019A {} (FF) {h} {} // TEMPERATUR_KENNLINIE
PARZUWEISUNG_PSW1 : 0025 (31,7B,B0,E1,E7) // kennlinie_01
PARZUWEISUNG_PSW1 : 00DE (31,92,B0,D8,E7) // kennlinie_02
PARZUWEISUNG_PSW1 : 00DF (31,92,BF,CD,E1) // kennlinie_03
I bolded the two values that are the min and max of the center line buffer. Take the hexadecimal values and convert them to decimal (use windows calculator in programmer mode); the converted value is degrees Fahrenheit.
-Abel
Cool.
Laptop arrived and I have the connector.
Just need time to try this again and install the software on the eBay laptop I just picked up.
Finally got everything installed but had one hang-up with WindowsXP. Seems like the Path creating utility isn't a valid win32 application.
I continued on anyway, just need to test connecting to the car here soon... Car is currently is pieces as I put in the race seat.
