Results 1 to 10 of 10
Thread: Anyone Successfully Using the M52 IAC/ICV With Boost?
    DeWitt, Michigan
    '97 540i/6, '97 328i
    As it turns out, I am currently adding turbos to two engines, one an M52, and the other an M62, and they share the same IAC/ICV setup with the big grommety thing. It seems to me that there is a slim chance of that thing holding boost, but I wanted to ask on here before I jumped to conclusions.
    TIA!
    Jun 2005
    New England
    F90 M5; E36 M3 Turbo
    Epoxy it into place or screw a hose barb fitting into the manifold.
    DeWitt, Michigan
    Ah hell, I was figuring that's what I would hear since I just finished installing the intake haha...
    As for an M52 question I haven't researched yet, can anyone tell me if there is a quick way to determine which fuel hose goes on which nipple? I don't think I've ever worked on a car before where they are the same size fittings if they are in the same location like these are..? Beginning searching and Bentlying now.
    Nov 2008
    Indiana
    97' 328is, 07' Titan
    Quote Originally Posted by tptrsn View Post
    It doesn't really matter, they do the same thing at the end of the day. Most cars have the FPR on the rail which is why they matter.
    1997 328is - Megasquirt PNP, Holset HX35, Deka 80lb injectors, SPA T3, Precision PW39 WG, Synapse Synchronic BOV, DKM Organic Twin Disc Clutch, Innovate LC-2 W/B, Mishimoto Intercooler, Mishimoto Catch Can, Mishimoto Rad, Devils Own Meth, Porsche 911 calipers with E46 M3 rotors, Corsa Exhaust
    DeWitt, Michigan
    Wow, bimmers never cease to amaze/confuse me!
    I was just reading about the crazy extra valve they have in the fuel system... Looks like I'll need to replace the fuel system sooner rather than later, just so I can understand what is going on.
    Phoenix,AZ
    99' 323is, 99' 328is
    Like this,it will never come out again.
    She's built like a steakhouse but handles like a bistro
    DeWitt, Michigan
    What exactly do you have going on there?
    IIRC, I tapped the CCV hole with a 1/2 NPT and plugged it, so next time I have the intake out I will probably just run an appropriate NPT tap in there (1/2 I think), and put a barbed fitting in it. Same effect as that epoxy job I suppose, but I just prefer threads when I can have them.
    Or is that an NPT threaded barb fitting with epoxy over it? If so, redundancy for the win I guess lol!
    Phoenix,AZ
    It's a threaded barbed fitting. Epoxy probably not needed but it works perfect.
    Apr 2015
    Tennessee
    1998 BMW 328i
    You can trace the fuel hoses from the check valve.
    DeWitt, Michigan
    Yeah, I ended up just running the hose from the filter to the rail. If isn't happy I'll switch them.
  1. Replies: 14
    Last Post: 07-26-2023, 01:27 AM
  2. Anyone use the OEM S54 radiator with FI + track use?
    By bmw_e30 in forum Forced Induction
    Last Post: 04-26-2012, 11:38 PM
  3. Anyone using the Xbox 360 Wheel with Forza 3?
    By Msilvia in forum Video Gaming
    Last Post: 12-26-2009, 03:30 PM
  4. Anyone using the E34 M5 clutch with stock flywheel setup?
    By 1NAWTY5 in forum 1996 - 2003 (E39)
    Last Post: 09-22-2008, 07:39 PM
  5. Anyone ever use the log out button?
    By UD///M in forum General BMW and Automotive Discussion sponsored by Intercity Lines
    Last Post: 02-20-2002, 06:38 PM
