H&R 12mm TRAK spacers with bolts
I am selling a used set of H&R TRAK 12mm spacers with bolts. for reference these were used on my E34 535i. The application information is from Turner Motorsport where they were initially purchased:
12mm = .47"
5/120 bolt pattern; 72.5 center bore
DR type = spacer fits in between the wheel and the hub. Longer wheel bolts are required.
Hubcentric = Yes, this spacer comes with a new hubcentric lip for the wheel to rest on
H&R's 12mm wheel spacers are Made in Germany and are TUV approved. H&R manufacturers their spacers from a super lightweight aluminum/magnesium alloy for excellent strength and also to save unsprung weight. The spacers are drilled for additional lightness and easy fitment. They are then hard anodized for durability. These are not low quality universal spacers - the bolt pattern, hub sizing, and other dimensions are designed to be used on BMW models only.
List Date: 3/26/2017
For more info, click here to view the original listing: H&R 12mm TRAK spacers with bolts
This item is no longer available.
Still available?
WUTCONE?
