Results 1 to 4 of 4
Thread: Dead transistors on ECU?
    May 2016
    Riga
    e30, e36
    Hello.
    I use Vems ecu for my project.
    Got home after long test run, everything was fine.
    In the morning car won`t start - no spark.
    I use m52 ignition coils, there is +12v to them.
    I opened Vems case and saw that there are 18 transistors, probably 8 for sequential injectors, 8 for sequential ignition coils and 2 extra, right?
    I took a multimeter un put it on restistance measuring.
    As I can remember 10 out 18 transistors showed me around 11 kohm.
    8 transistors showed me nothing. I tried to measure them inbetween three transistor legs in all possible variations and it didn`t show anything. So, I have 8 dead transistors?
    I had one bad grounding on ECU, could it done damage?
    I hope You can help me with answers, paid a lot for this ecu and have used it for a few months..
    May 2016
    Riga
    e30, e36
    So, looks like transistors are alive, got car started. But, I do not know why it did cut spark off.. Groundings are good actually.
    Jul 2004
    Houston, TX
    36 Cylinders
    Crankshaft position sensor?
    -Abel
    - 2000 Z3: Many Mods.
    - 1999 S52 Estoril M Coupe
    - 2016 Mini Cooper S
    May 2016
    Riga
    e30, e36
    Crankshaft position sensor works. When I tested outputs, no igniton signal in test mode. I am confused..
  1. has anyone installed the e46 m3 dead pedal on an e36?
    By m3j0n in forum 1992 - 1999 M3 (E36)
    Last Post: 11-18-2003, 05:29 PM
  2. has anyone installed the e46 m3 dead pedal on an e36?
    By m3j0n in forum BMW Rides & Events
    Last Post: 11-17-2003, 07:24 AM
  3. "Dead" coils on my H&R coilover setup?
    By cc///m3 in forum 1992 - 1999 M3 (E36)
    Last Post: 11-20-2002, 05:13 PM
  4. Question about EEPROM chip on ECU
    By 99M3 in forum 1992 - 1999 M3 (E36)
    Last Post: 09-22-2002, 11:55 AM
  5. Dead spot on 2nd between 4 to 5k RPM...HELP
    By Saul in forum 1992 - 1999 M3 (E36)
    Last Post: 05-03-2001, 09:05 PM
