Exterior looks amazing, well done. Look forward to pics of engine and interior. I'd take it to a BMW mechanic to do the t-belt, but that's just me. With 16k miles seems it has potential to be near mint again, don't want to screw it up if you're not familiar with it already. (edit to add i'm an engine novice, full disclosure)
'92 318i Cabrio- Alpine White
When changing timing belts has anyone ever took one off that looked bad. I change my 325ic every 60,000 miles which is between 6 to 8 years. They all look like brand new, no cracks, no frays and still flexible. I drive my car easy, no jackrabbit starts etc. What have you found?
I replaced a 10yo belt on a newly bought e30 and it looked to be one starter crank from breaking. OP
likes to live dangerously by starting and driving this car despite the warnings. Let's hope his luck holds
87 Zinno Cabrio 98k Barn Find. Build thread http://www.r3vlimited.com/board/showthread.php?t=268987
87 Lachsilber ETA Time Capsule. bought w 125k from 87yo original owner
Cabrio deck lid & hinge struts (w sleeves) now for sale. See the link below for more info
New "made in Europe" seat shocks. PM for details
http://www.bimmerforums.com/forum/sh...ot-Seat-Shocks
Y'all seems to roast me on the fact that I haven't done this belt even-though the car isn't even street legal. I will take it to a BMW mechanic when I have the money but I'm in high school so I don't have a six figure job and I have two other cars that take a lot of maintenance. But when I get the money and the car registered I will get it done. So that being said some of y'all just need to chill.
You've asked for advice and been given a huge red flag based on experience about the potential to brick your engine and you've chosen to ignore it.
What did you expect ?
oh..and the barn find in my sig I bought with a broken timing belt after the PO figured he could drive it a little longer.
I'm soon to fine out for the first time how hard it is to change a T-Belt..A long weekend coming and have all the parts i need so that what i'm doing and nice weather to boot..
You have to realize that you're 16, so you're an idiot. And before you try to argue that you're not, let me point to exhibit A. Everyone told you to change the timing belt before you started it, but you started it anyway. That has to be an original 30 year old timing belt. Starting it at all before changing it is incredibly risky. M20s are interference motors, that means that the valves will hit the pistons if the timing belt breaks. I have seen many many broken belts. I have also picked up many cheap e30s because some idiot didn't do what far more experienced and knowledgeable people told them to do. Let me tell you, changing the cylinder head on an e30 is a far harder job than the timing belt.
Changing the belt is not hard at all. I did my first e30 timing belt job around your age, here I am, nearly 15 years later and it's the first maintenance item I do whenever I buy another e30. Case in point, 2 months ago I picked up a non running e30. First maintenance item I ordered that night? FCP euro timing belt kit. And I even knew when the timing belt had been done last. Good thing too, because the tensioner was wobbly and the belt was probably a few hundred miles from shredding. It's also a great time to replace all your other belts too, since they have to come off.
Make sure you soak every nut and bolt you come across with penetrating fluid like pb blaster before you take it off. That goes double for any bolt/nut that sees heat like the exhaust.
Edit: Feel free to get angry and shut your ears to people that know better. You're only further proving my point. We've all been there at one point. Angry and angsty at these stupid adults who clearly don't understand. But really, we're just shaking our heads and laughing at you. /getoffmylawn.
If your e30 runs bad, switch to Megasquirt first. Then try new spark plugs, cap and rotor, wires, oxygen sensor, crank shaft position sensor, coolant temp sensor, air flow meter, idle control valve, throttle position sensor, digital motor electronics unit, harmonic balancer, fuel injectors, engine harness...
Like I said I plan on doing it. I had to have the car moved with out a tow truck. I really had no choice but to drive it, at least away from the sellers house. Also I never said that you or anyone else on this forum doesn't understand. Had the seller allowed for the car to be towed away I would have done that. Also coming to the conclusion that I'm an idiot just based on this forum and my age suggests that maybe there's an idiot at the other end of this discussion. That being said thanks for the advice.
they're just busting your balls a tad man. we all care about the chassis here and no way in hell do we wanna see one get crushed thru avoidable stupidity. bmw forums in general and e30 forums in particular are raucous places. no one would bother replying at all if they didn't give a shit, or see you eventually be successful with the car.
coulda left it right there lol
not sure that reads entirely the way you meant lol. that said grow a little thicker skin, pull up a chair, and benefit from the knowledge pool of those who have wrenched before you. it'll be alright. but your only gonna find out if you stick with it.
You guys are way too nice, it does show that other E30 owners attempt to be helpful. But, who cares what he does with the car. We told him, so let him do what he wants. If it blows up, so be it...his problem. He has been warned numerous times. So far, lucky kid.
Well just posting this in this thread for a final update. Belt has been ordered! Car was overheating when driving(just on my driveway to move it around) so I put in a new radiator and thermostat. Still overheats. Now the starter blew. So I have over $600 in the car and really can't afford anything else for it so I am selling it. Thanks to all on this forum for the help with this car!
I have 2, otherwise i would buy it from you instantly. If i was closer, i would seriously consider rescuing the car however....C'mon people, someone grap this beauty..
I think I have a buyer lined up already. Thanks for the help everyone!
just throw the belt in with the sale. don't bother installing as the head sounds like it's gonna need to come off any way. think twice about selling. e30's while beginning to get rare, are still great cars to both learn on and drive. they are inexpensive to work on when compared to other road going classics, and respond well to simple modifications. plus they look great and will only head north in value over time when well kept.
Well just hope it goes to a good home that will give it the TLC that it deserves..May i ask how much you asking for it....
Nice E30 too bad you are selling it, all it takes is some time troubleshooting it and some $$ to fix the overheating etc. but definitely worth holding on to. Someone will benefit from your loss.
In the long run you would find that an e30 is actually an extremely cheap car to drive and maintain, specifically due to their reliability ...it's the type of car that takes care of you when you take care of it. That said, if I were you, I'd buy a Bentley manual for the e30 and follow the directions. Timing belts are easy, and if it hasn't broken before you change it, and you are careful not to turn the crank or the cam pulley, you don't even need to bother with the timing mark, although double checking can give piece of mind. Really though, if you can't change an e30 timing belt, you probably don't ever want to wrench on any vehicle, it's really not that challenging. Good luck in whatever you do with it.
Thanks for the advice, I think it is well within my skill level as I have done water pumps, radiators, starters and things like that on my other car. I haven't thought much about the tbelt as I have been spending hours trying to do starter as I can't seem to get access to the last bolt. I will do tbelt as soon as starter is done. The belt should be made much easier as my friend is letting me use his quickjacks which make going under the car so much easier. I'll let you all know what happens with it.
