Wastegate/spark plugs/what else?
Turn it back to 1bar and see if the issue remains. Probably messed something else up. Correlation / causation scenario.
Not plugs, probably tuning issues if not mechanical error.
1989 535i - sold
1999 M3 Tiag/Dove - sold
