Results 1 to 5 of 5
Thread: Weak Boost, Low power when accelerating
    Apr 2015
    1710 Marina Dr, Columbus,
    2007 BMW 335I Sedan
    Code indicates pressure too low at high pressure side of throttle on my 2007 BMW 335i. No waste gate rattle. I'm thinking maybe collapsed vacuum hose preventing waste gate from closing properly preventing proper boost pressure behind throttle. Any comments would be well received.
    Dec 2012
    North Carolina
    2009 335i M-Sport Coupe
    If you have the actual code number, that might help. I'm thinking boost leak on this one, maybe a cracked charge pipe or loose hose. If you want diagnostic software, I can give you anything you want from the android carly app to the dealership ISTA program.
    Jan 2016
    Ca
    2001 525it
    Check all those little vacuum hoses
    Feb 2017
    Boise, ID
    2008 E61 535xi Touring
    Post #14 has some great info to follow:
    http://www.e90post.com/forums/showthread.php?t=894084
    I also replaced the hard lines going over the valve cover with 3.5mm hose too just in case they eventually developed problems.
    Hardest part is getting in the small spaces to change out the hoses going from the boost solenoids to the wastegates, but take your time and you'll get it.
    Jan 2017
    Las Vegas
    Start by checking the charge pipe, stock CP is prone to failure
  1. Bmw e36 low power when hot.
    By BMW325issport in forum 1991 - 1999 (E36)
    Last Post: 05-25-2012, 05:07 PM
  2. misfire/rough idle/ ticking/no power when accelerating
    By BmwCI323 in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 09-26-2010, 03:15 PM
  3. 1995 M3 looses power when accelerating
    By NoEmailMan in forum 1992 - 1999 M3 (E36)
    Last Post: 12-07-2009, 03:38 PM
  4. Replies: 10
    Last Post: 08-21-2009, 12:08 PM
  5. No power when accelerating
    By capelass in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 04-17-2009, 11:20 PM
