Page 2 of 2 FirstFirst 12
Results 26 to 29 of 29
Thread: EFR turbo fitment on SPA manifold
  1. #26
    Vancouver, B.C., Canada
    '97 M3
    I bet the Max PSI high bottom mount twin scroll and an EFR 9180 0.92 with a 4 port boost solenoid would be a kick ass combo.
  2. #27
    Sep 2008
    Toronto, ON
    6465 328ti
    Quote Originally Posted by chikinhed View Post
    I moved over to a 4 port after my 3 port mac solenoid couldn't control past 2x my wg Spring (14psi)
  3. #28
    '97 M3
    Quote Originally Posted by e30kid89 View Post
    I moved over to a 4 port after my 3 port mac solenoid couldn't control past 2x my wg Spring (14psi) Sent from my iPhone using Tapatalk
    What boost controller are you using?
  4. #29
    Toronto, Canada
    E36 Turbo
    Probably his MS3
  1. FS: GT3076R T3 Turbo Parts + T3 SPA Manifold + Engine Mount + Injectors
    By kojohns in forum Forced & Chemical Induction Parts
    Last Post: 09-20-2014, 03:58 PM
  2. Replies: 0
    Last Post: 09-13-2014, 03:52 PM
  3. Turbo fitment with spa manifold
    By hobbit382 in forum Forced Induction
    Last Post: 05-16-2010, 11:06 AM
  4. My turbo build Gt35r Spa manifold
    By BMuu in forum Forced Induction
    Last Post: 12-08-2006, 06:56 PM
  5. twin scroll turbo on spa manifold
    By elements018 in forum Forced Induction
    Last Post: 09-28-2006, 11:15 AM
