Hey guys, would an EFR7670 with the internal wastegate fit without issue on an SPA log manifold?
www.facebook.com/Undr8dEmpireLlc Instagram: @UNDR8D_EMPIRE
Scarlet V2 - #Project333Ti - http://www.bimmerforums.com/forum/sh...(-Project333Ti)
External wg I know will fit 100%. Internal may be too tight
the internal wastegates dont work. Dont bother. Even without the IWG, its still a better turbo then any PTE by a long shot and worth using.
328i Sedan Twin s366's, 6.0LS, TH400, MS3 Ultimate
9.20 at 150 on 22psi
Do the spa, weld the WG port shut. I have a housing for 6266 with WG port built off of it you can buy.
1996 332IS
Built 3.2
Technique Tuning 80# tune.
1/4 mile 10.84 @ 136.72
WWW.CESMOTORSPORT.COM
1996 332IS
Built 3.2
The EFR IWG is just fine. It even controls boost on 13B rotaries with 8374s down to pretty low boost. It's all in having a collector that doesn't take a sharp 90 right before the inlet.
If you need an EWG to bandaid for your poor collector design, don't blame the turbo design...
The 9180 13b i tuned and the 8374 s52 i helped a forum member tune couldnt stay under 20lbs with the IWG. With and with out the turbosmart actuator.
And CES found the IWG 8374 insufficient to control boost on single turbo conversion N54 motor BMWs when fitted with twinscroll manifolds.
I researched this issue when confronting boost control problems with EWG 8374 on my twinscroll manifold S52. I would have happily changed to an IWG if that alone would have worked. But the research I did suggested an IWG 8374 would not control boost on a twinscroll manifold S52.
If you are not trying to run low boost, you might not have any issues.
Bump, anyone in the know if an EFR8374 would work on a SPA?
9180 fits, 8374 should...all depends on what housing is used
Yup, moved over to a spa t4 to accommodate the efr
There is a boost logic manifold for sale for $500 I'm highly surprised its still there. That has fit a 366 iirc.
1996 332IS
Built 3.2
Well, for a tubular manifold, its probably one of the best on the market. It controls boost down to 1-2 psi. WG placement is great for fabrication compared to an spa. Sure open collector, but can't compare to a TS that is tough to find under 1k.
That said, that boost logic would be best Mani for 500
1996 332IS
Built 3.2
I bought a brand new custom bottom mount twin scroll for 650$ it's still holding up! No regrets with TS!!!
